Forge Wastegate actuator?
Old Sep 8, 2005 | 04:02 PM
Mike@Forge's Avatar
Originally Posted by dan628
Correct me If I'm wrong but with a MBC don't you cap off the 2 outlets on the wastegate actuator??? Wouldnt it be pointless then to upgrade it if you already have a MBC???
I mean this in the very best way but you are wrong.
The part underneath the airbox that has the two ports on it as well as the electrical connector is in fact the ECU controlled boost control solenoid. It is essentially an electronic boost controller that is connected directly to the ECU.
The actuator is the goldish colored stamped aluminum piece with the bracket and rod that sits right behind the center of the radiator and connects to the turbo.
Our unit looks like this, but is essentially the same shape as the stock piece:
(It mounts upsidedown from this picture)
def1
Feb 2, 2017 10:34 AM
snow306
Nov 1, 2016 03:46 PM
ArchieBabes
Mar 13, 2010 01:45 PM
kouzman
Apr 3, 2008 04:35 PM
kimletrim
23
Oct 10, 2006 06:32 PM
