Whats wrong with my clutch?
Old Sep 4, 2005 | 01:54 PM
bigjhoney's Avatar
Ok heres the deal,stock clutch, 23k miles.... my clutch has been acting weird for some time, but lately its been getting worse.At idle when the ac was on I would hear a knocking sound( tob I would presume) now its starting to get louder with no a/c. Before if I would downshift without rev-matching I would hear a loud whine and a vibration at the clutch pedal until the revs matched. And little by little as time went you would hear a metal clank once in a while when I shifted( lower gears, at low rpms). And every once in a while it would chatter...but never would slip. Now it chatters like crazy, especially in reverse. You hear metallic clunk everyother time i shift. 1st 2nd ,3rd, and sometimes 4th are real notchy (2nd gear is the worst, sometimes cant grab it at high rpms(locked out, no grind). Whenever I shift at high rpms my car acts as if im still on the throttle and is like delayed which sometimes makes me miss gears( usually only happens from 3rd to 4th gear). I understand my clutch/flywheel are done, but are all my problems contributed to the clutch.wheel( like notchy gears, rev matching problem, etc.)? Thanks in advance.
Old Sep 4, 2005 | 04:20 PM
bigjhoney's Avatar
anyone?
Old Sep 4, 2005 | 04:39 PM
Compjoc's Avatar
you might need a tranny rebuild with the grinding, mis-shifts and notchiness, go tell the dealer about it. You'll probably need a new clutch too
Old Sep 4, 2005 | 04:42 PM
fugly's Avatar
hi ... i have clutch problems with my evo 7 all the time when its cold
once the engine is warmed up ..
all my hassles go away ...
but it sounds like you really need a engineer .. to have a butchers @ it....
it really should'nt be grinding , or knocking ,
the first thing i would do os change the gearbox oil ...
@ least then your be able to see ...if theres metal in the oil...
but if you have a warrentee get in to the dealer asap...
Old Sep 4, 2005 | 04:51 PM
bigjhoney's Avatar
I went a while ago...all they pretty much said is that that warranty wont cover it.
Old Sep 4, 2005 | 04:56 PM
Compjoc's Avatar
They won't warranty your clutch but if you have grinding problems in 4th or 5th gear they should warranty it, there is a TSB out on grind gears. If they pull the tranny to fix the grinding gears, they should throw a new clutch in for fairly cheap.
Old Sep 4, 2005 | 05:04 PM
fugly's Avatar
compjoc
has a point there ..... ya gear box should be under warrentee ...
i can understand ya clutch not being ...
but again it should be down to the dealer , to put right .... you just end up paying for a clutch .....
just be a bit more persistent ....
Old Sep 4, 2005 | 05:17 PM
bigjhoney's Avatar
I dont have any real grinds, just alottt of notchyness, 5th gear is fine never had a problem with it.
Old Sep 4, 2005 | 09:53 PM
Compjoc's Avatar
Try some different tranny fluid to cure the notchiness (BG synchroshift).
Old Sep 4, 2005 | 11:41 PM
bigjhoney's Avatar
Put that in about 5k miles ago, at first was ok then its back to the way it is now. Is it possible for the clutch to cause all these issues?
Old Sep 5, 2005 | 07:00 AM
fugly's Avatar
bonjour ....
the notchey ness / grinding aint right ... you have to go show a dealer ..
get them to test drive it ....
Old Sep 5, 2005 | 11:30 AM
Compjoc's Avatar
Originally Posted by fugly
bonjour ....
Yea, what fugly say. You'll need to get ur tranny looked at. Alot of people complain of a clunking sound from the tranny which turns out to be a loose motor mount.
xenonk
Driving Techniques
11
Feb 26, 2007 07:37 AM
Pure Playaer
26
Dec 25, 2006 10:11 PM
bigjhoney
19
Nov 12, 2005 06:20 PM
TrojanMan
Apr 6, 2005 09:52 AM
lancer03_Mike
Lancer Troubleshooting
24
Jan 17, 2004 10:20 AM
