Forge Actuator 25psi straight to Redline!!!
Originally Posted by Ted B
Someone else can do that for you, so getting good dyno data doesn't require purchasing a dyno, just competent independent testing.
Like some others here, I'm already running 25psi in the midrange, so that much is accomplished without this part. What I and others would like to see is if there is anything to be gained by forcing the boost pressure issue at high rpm, where the compressor is spinning well out of its efficiency range. One recent post of a MAF log says 'no', but we'd like to be able to look over a dyno comparison.
I am running about 2126HZ currently and a/f is clockwork to tune. Intake type will have an impact on the frequency of the MAF at the same "actual" airflow level.
i got this part because i started to have some weird boost issues and people told me that maybe my stock actuator was crap. installing this for me was not an easy task. i have the buschur fmic and upper piping kit. the actuator is wider than the stocker and really pushes against the lower turbo outlet pipe. you really need to take the starter off to gain easier access to the bolts that hold the pipe to the compressor housing of the turbo.
and right now i am having weird boost issues again. my boost hits hard to about 20psi by 3K rpm then around 4500rpm my boost floats to about 22/23 and back down to 20psi.
FYI...i have the blue spring.
anyone have any ideas?
This may be a different story on the 5sp, but in no way would I ever recommend removing the starter to install the WG. I would remove the radiator WAYYYY before anything else. Like I stated the optimum situation is to remove the whole turbo and manifold. Remove all the heatshields when it is out.
Originally Posted by tke_413
My car started to do the same thing until I replaced the Hallman MBC...do you have one of these? If so, they had a bad batch where the springs were taking a crap...something to look into.
i do have a hallman with the stiffer spring. I have had it in the car for almost 2 years now. The hallman I have is the one that you can control from inside the cabin.
Originally Posted by John@GSC
Sorry I had over looked that. Here they are.
1.78
5.216 @ 65.28
8.066 @ 86.46
1.78
5.216 @ 65.28
8.066 @ 86.46
The 60' was better on the new run, which can account for a little bit of the ET increase, but not all of it. The ET dropped .17, which is interesting, since the 1/8th mph is the same, but maybe the higher speed through the 330 helped to better the ET. It's not really definitive, though. The car is making the same power as before it seems...
At some point you are going to be over spinning the turbo. Causing more heat and shorter turbo life. Also at some point you will be pushing the boost pressure to exhaust pressure ratio toward the theoretical "limit" which can lead to massive internal back pressure, pre turbine and melted exhaust valves. With a leaner mixture at a "normal PSI", you could make the same power by increasing volumetric efficency.
Just my .02
Just my .02
Increasing volumetric efficiency of course, increasing boost dropoff and bringing us back to the whole reason for the Forge WG upgrade in the first place. No thank you....
_____________________________
30 psi, stock turbo member #0202
Guest
Posts: n/a
Ok, so after the Forge WGA, it ran the same mph in the 1/8th, but was 2mph higher at the 330'. I'm not sure if that's telling us anything. When I say I'm not sure, I mean that I am not educated enough to know what really caused that increase at the 330 and then decrease from the 330 to the 660.
John
The speed didn't go up cause there is thing called a rev limiter. When you hitting it going through the traps your car will slow down a bit.
To the contrary, though, when I go to the 1/4-mile track, I hit 87-88mph in the 1/8th, which means I'm definitely already in 4th and have been for a measurable amount of time, especially since I'm on the stock ECU with a 7600 rpm rev limit. I shift at 7200 anyway, so I'm hitting 4th well before the 660' mark. Are you guys just holding it in 3rd all the way through? Did you not try to hit 4th? Were you doing the same thing before the WGA (hitting rev limiter, staying in 3rd)? You may not be able to see the difference until going for a full 1/4-mile run.
...at a "normal PSI", you could make the same power by increasing volumetric efficency.
