Does new BOV give more power?
By just replacing my BOV with an aftermarket one will I actually gain anything. I have a cat back on order and a replacement air filter on order. I am getting flashed this weekend. With those things combined will a new BOV be of any help?
Thanks Dean
Thanks Dean
A new BOV will only be useful if your stock one is currently leaking boost. The new one won't really add any power directly, but it will help down the road whenever you get a MBC and turn up the boost. The stocker isnt' good for holding more than 20psi, if that. Just make sure you get a recirculating BOV, not a VTA one. Too many problems with VTA. The best two are the MR DV and the Forge.
Thanks Dean
Thanks Dean
AC556k, please, for the love of God, USE THE SEARCH TOOL. You will find far, FAR more information regarding this question than the little bit that these guys have told you. You will learn about the stock BOV, you will learn about aftermarket BOVs, you will learn that it does add power, but then you will understand WHY it adds power, you will understand when it adds power and when it doesn't, you will understand when to get one and when not to, and you will understand which ones you should get and which ones you shouldn't.
I'm begging you..........PLEASE SEARCH and stop asking these unbelievably basic questions.
I hope you all see the monster that has been created. This is his _4th_ thread started that asks a completely mundane question that has been answered a trillion times. This is what happens when you don't make people search and you just tell them the answer like this is some pre-school class where we spoon-feed everyone.
I have been on this site for less then a year, and have found all the info I needed just by searching. If your lazy or dumb pick up the phone and call one of the Tuner shops that support this site.
Thanks Dean
Thanks Dean
Originally Posted by bdking57
you will actually loose power with a bov from running richer.
When I changed from stock bov to Forge RS bov, I gained like 10 WHP.
I found out that my stock bov starts leak at 18 psi. and there is constant small leak on any low boost level. you can find out if you do pressure test your bov. Stock bov is not tightly sealed like after market bov. That is why you get smooth operation. and after market BOV will never be smooth as stock unless it does leak like stock bov. If you are boosting more than 20 psi, BOV is definite buy!
anoter option is just to find a non leaking stock bov.. many people have had leaky ones, however mine holds find at 21 psi and the car spikes to 23..
What happens is the stocker is always leaking, but your MBC is telling the turbo to produce 21psi, so in order to maintain 21psi, it pushes out MORE than 21psi to overcome the leaking boost. In the end, you're blowing hot air, because the turbo is being forced to produce far more boost than is efficient on pump gas, when you could be producing 21psi and holding 21psi with a proper BOV like the JDM MR DV.
boostislife
12
Nov 8, 2016 03:03 PM
rlazer5000
Jul 13, 2005 09:58 AM
