Oil Leaking from this hole. What is it?
I just changed my valve cover, and there were/are no leaks along the edges or near the spark plugs.
Get a pop up blocker, I don't have any trouble with that.
Originally Posted by superman105
hey why do you have popups in your photo when people try to help you out
there is also spyware on it !
what's wrong with you
its hard to tell from those pictures..
Also your description is difficult to follow without good photos, but it is implying the PCV Valve but the photo your showing looks to be too small for it..
BUT, the PCV valve being off, broken, or missing would result in oil coming out and smoking..
Originally Posted by nutrulz
I'm not that dumb, If I spilt oil it would burn off, and then no problem. This is slight smoke whenever I am stopped all the time.
I dont know how old your car is, but if your getting an excessive amount of blow by into the crank case and the PCV isnt enough to release the pressure, you might be blowing oil out of the dipstick and onto the valve cover or even from the oil cap. I had this happen to me a few times. I had to change the o-ring on the dip stick and get a catch can so the motor "breathes" better
