How come the DSM 20G didn't surge?
Old Oct 10, 2005 | 01:50 PM
nefblkevo's Avatar
I have definately experienced surge on the stock turbo
Old Oct 10, 2005 | 01:54 PM
Soon2BEVO's Avatar
The only time I had that issue with my stock turbo is when I was in 5th gear on the Parkway and I was at around 5000rpm (lil over 100mph) and whenever I got on the throttle partialy it was sputter and surge...
Old Oct 10, 2005 | 03:48 PM
Elitist Evo's Avatar
From: Where Ever the Smoke and Rubber takes me.......
Yeah I can get my 03 to surge on command. I would immagine a larger compressor cover would aid in any surge by adding lag.
Old Oct 10, 2005 | 04:25 PM
Creamo3's Avatar
Originally Posted by Soon2BEVO
Creamo, can you comment on this surge isue since you have the 20G? Also hows spool, I see you have the TME version which I would want...
The surge is definately present but there are ways to alleviate most of it. First off, is driving style. The turbo will surge for me between 4k-5k if I am in a higher gear where the engine is bogged down and is slowly building boost. I experience little to no surge if I am in a situation where the revs are high and I am shifting gears. The spool is somewhat laggier than stock, but I am still able to build 20psi around 4k. I am installing a clutch/lightweigt flywheel which should help this some. Another way to alleviate this surge is to loosen the BOV to allow it to release pressure more easily. Dave mentioned that he is working on something that will eliminate this surge and hopefully increase power so we shall see. The turbo feels good, but it is hard to say due to the fact that my stock clutch is slipping. I am hoping to hit the track when the clutch is broken in and AMS is having a dyno day at the end of the month that I will attend. I feel this turbo has good potential once the bugs are worked out of it and people's setups are done right
Olms2468
Jan 3, 2017 11:36 AM
socalx_dsm
Jun 18, 2016 05:36 PM
clip14
18
Jan 26, 2016 02:03 PM
KevinD
Dec 9, 2010 08:16 AM
blackdemon
26
Jan 20, 2008 01:44 AM
