Pics from ATP 3037S turbo install...MBWW
So after months of saving up and buying misc parts, I finally installed everything. Previously I was vishnu stage 1 with a megan racing header. My friend and I spent almost two weeks to finish the project, working throughout the weekend and after work on the weedays. Everything came together and now it just needs a good tune and better connections on the lower IC pipes. Currently have the Xede and a slightly tweaked map that is running pretty rich at the moment. Future plans are to convert to standalone and get a custom tune in the next month. The actual install of the turbo was probably the easiest part, but the whole project was definitely an undertaking.
stock turbo vs. the ATP 3037S w/ceramic coated exhaust housing
getting ready to pull the engine
partner in crime...
removed the whole engine/tranny/transfer case together. I think dropping the subframe would have been a lot quicker and less hassle.
pulling part the engine
transmission
stock clutch and flywheel
stock friction plate, actually didn't look bad at all after 18k miles and numerous track days
looks like coolant leaking past the gasket?
one part of the block had slight green discolorations to it underneath the head gasket.
getting ready to install revolver cams and new springs/retainers. BTW if you can get the right tool save yourself the hassle of getting creative. I didn't want to pay for shop labor so we customized a tool that worked but was a PITA.
revolver cams/springs/retainers installed w/vishnu cam gears
getting naked
removing the balance shafts with the RRE kit. took a little while to figure it out, after that it made sense. replaced two of the races to keep the oil pressure up. also had to buy two new gaskets.
balance shafts....those things are heavy!
ARP rod bolts installed to specs.
stock pistons....I wish I had the money to go with new rods/pistons/stroker, but from what I have read the stock setup is pretty stout.
close up of the stock piston, took them out to install the rod bolts
Greddy head gasket at 1.4mm, and ARP head studs also installed to ARP spec
exedy twin disc clutch/flywheel
new stainless braided clutch line
working on suspension bushings
new bushings
About to replace the rear diff carrier bushings. I could physically move the whole diff by hand with the stock pieces in place.
you have to press out the stock mount to put in the new ralliart units.
some customized tools for pressing out the bushings
720cc Denso injectors
getting ready to go back into the car. also removed the A/C and used the Evo RS serpentine belt, worked out great. I never use A/C up here anyway.
ceramic coated megan racing header
mocking up the turbo and plumbing
almost done...
as I'm driving the car now...still need to clean up some of the IC plumbing, and recirc the BOV. so far there are only a few times where the VTA gives me any problems. one thing I noticed either from the VTA or the relocation, is that the car feel much more responsive after shifting.
Overall impressions, the turbo sounds like a jet engine, the cams are very lumpy at idle and a little bit more difficult to drive but sounds amazing above 4k rpms, the clutch feels better than stock and completely streetable. Definitely need a custom tune, we did some logging on the wideband as well as some logging just to make sure everything is safe for the meantime. I'm sure I left a few things out, I took a TON of pics but didn't post them all.
partner in crime...
transmission
getting naked
new bushings
almost done...
From: Where Ever the Smoke and Rubber takes me.......
The ATP kti DOES bolt to the stock manifold, the Megan manifold fits like stock. I am still not a fan of that ATP kit as I simply do not trust that custom exhaust housing. You may also want to consider a better FMIC then stock.
yeah that is about 1000 rpms slower then what is possible with a RNR/AMS kit.
