windshield wiper washer same as 50/50alcohol & water?
Old Oct 16, 2005 | 05:43 PM
yesevo's Avatar
??? does windshield wiper washer contains alcohol??? or straight water???
Old Oct 16, 2005 | 05:45 PM
The_Predat0r's Avatar
I also have been reading that about using washer fluid on the alky!
Is that a joke? Is that true? why?
Old Oct 16, 2005 | 06:02 PM
yesevo's Avatar
dont aske me ...is it same as denature alcohol and water mix 50/50?
Old Oct 16, 2005 | 06:19 PM
CDO's Avatar
CDO
I suppose it depends on where you live if washer fluid contains alcohol. In northern climates it's needed to prevent the water from freezing. It might also be found in warmer climates as part of the cleaning process of the glass, I don't know.
The percentage of alcohol depends on what kind of alcohol is used and for what temperature. Washer fluid good for -40F would have more alcohol in it than one good to only -25F. And like I said, it depends on what kind of alcohol they're using too.
Old Oct 16, 2005 | 06:37 PM
Mario's Avatar
Usually 8% methanol to lower the freezing point of the fluid..............use a 50/50 methanol mix for alky............
Old Oct 16, 2005 | 06:43 PM
SlowCar's Avatar
http://www.ashchem.com/adc/chemicals...=3&is_header=N
Old Oct 17, 2005 | 09:39 AM
MyCre8n=Evlshn's Avatar
Registered User
So we're all trying to figure out, for anyone who knows, is there a common w/s washer fluid that is 50% methanol??
Old Oct 17, 2005 | 09:46 AM
Cajun Power's Avatar
OK, you guys are getting way too creative.
Old Oct 17, 2005 | 11:35 AM
C6C6CH3vo's Avatar
There is a product at my local BX that contains about 50/50 methyl/H20 it's concentrated window fluid undiluted.
The stuff in the common one gallon jugs is about 5 to 10% methyl alc. - mostly water.
Old Oct 17, 2005 | 01:06 PM
BaLListic_EVO's Avatar
mmmmmmmm i recall seeing someone that made a flame thrower out of some washer fluid... it was factory bmw fluid though... not sure of the alcohol content....
