best engine oil?
Old Oct 19, 2005 | 10:22 AM
  #46
k270kmh's Avatar
Castrol SLX 0W30, recommended by my Local Mitsubishi dealer.
Old Oct 19, 2005 | 10:44 AM
  #47
turboDan's Avatar
Originally Posted by i11matticc
ok, i guess i was misinformed, i apologize...you learn something new everyday...
N/P,we all make mistakes,but it takes a Man to admit when he does.Just trying to help so people don't get the wrong impression on Mobil 1,and no,I do not work for or have any interest in Mobil/Exxon.
Old Oct 19, 2005 | 08:00 PM
  #48
GDB's Avatar
GDB
Originally Posted by WINSTON
bingo!
Motul 300V for racing and 8100 Ester E-Tech for street.
winston
Hehe... judging by how this thread is turning out, I guess NOBODY knows what we're talking about...
Oh well, ignorance is bliss...
Old Oct 19, 2005 | 08:07 PM
  #49
Dan2510's Avatar
Engine oil I think is highly debatable, kind of like what type of gas do you put in your engine and why? However, If I had to pick it would be Royal Purple or Mobile 1.
Old Oct 19, 2005 | 08:09 PM
  #50
gofaster87's Avatar
20/50
Old Oct 19, 2005 | 08:21 PM
  #51
EVOLOVE's Avatar
I'm interested in what you're talking about, but ignorant. Can you elaborate please?
Old Oct 19, 2005 | 08:24 PM
  #52
JTB's Avatar
JTB
Just an observation - When I push my car hard (mountain drive or track) with Mobile 1 5w30 I found that my oil pressure would fall in the toilet at idle - .25 bar or less. Once I let it cool it would again rise back up to normal - about 1 bar. Needless to say this made me really uncomfortable!
I have since changed to Redline 10w40 and have not seen the problem again
For those of you that are wondering why Mitsubishi recommends 5w30, I believe that it has to do with their belief that we are going to thrash on our cars when cold. Since Mitsubishi can't trust us to warm up our cars before driving hard they give us an oil with a low cold viscosity. The 5 represents the weight of the oil when cold, and since this is a low viscosity, damage and wear when cold is reduced.
BTW -- the 30 or in my case 40 in 10w40 in the viscosity rating when hot. One of the reasons for my better oil pressure readings. That and I believe Redline is just better oil
Old Oct 19, 2005 | 08:29 PM
  #53
fletch's Avatar
Royal Purple 10x30. This will be the third car I have had it in, getting ready for first oil change.
Old Oct 19, 2005 | 08:36 PM
  #54
GDB's Avatar
GDB
I may get flamed for this for not giving hard data/links because I lost the links
IN SUMMARY:
1. Ester-based oil 'clings' onto your engine parts because of its polar nature. Therefore in situations like cold-starting your engine, when the oil hasn't been pumped thru the system, your engine will still have a thin layer of oil (because of the said polar nature).
2. Ester-based oil is more resistant to shearing.
3. There's a third one which I don't remember now
I came across this couple of years ago when searching more on Motul, which IMHO is the best oil on earth for vehicle applications.
Oh yeah so my answer to the question of this thread is: Motul oil.
Old Oct 19, 2005 | 08:37 PM
  #55
TEXSRT4's Avatar
i think royal purple is the best, i made this point earlier but no one commented on it, mobil 1 is not a pure synthetic anymore. this all started when castrol syntec used a close to synthetic as their oil and labeled it synthetic. mobil sued castrol over this, claiming false advertising, however castrol won the lawsuit.
because of this, mobil figured if you cant beat em, join em, and decided to do the same, which is why mobil one does not say synthetic, is says syntec or some other $hit, i forgot exactly what, they did the switch over as well because it cost less to produce.
in conclusion, royal purple is the only true synthetic that i can think of off the top of my head, if anyone disagrees with me or would like to add any additional input, id like to hear about it because id be interested in hearing how others feel about this
amsoil also uses a fully synthetic base stock for their oils!
Old Oct 19, 2005 | 08:38 PM
  #56
EVOLOVE's Avatar
IN SUMMARY:
More than enough info to get started on some research on my own. Thanks.
Old Oct 19, 2005 | 08:39 PM
  #57
mdosu's Avatar
Originally Posted by Jin4g63
I use 5-30 is that okey?
you'll be fine, I use it for the winter months here, and I park my car outside. Just don't race with it in your car or overuse it and you'll be fine, but then again, who races when it's below freezing outside anyways?
Once it doesn't freeze overnight anymore...probably around early May, I will once again switch to M1 10-30
Old Oct 19, 2005 | 09:19 PM
  #58
WINSTON's Avatar
Registered User
a little more on Ester oil.
http://www.motul.co.jp/eg/fact_sheets/estel_oil.html
BMW Motorsport performed a little test in which they took several crankshafts and dipped them into several different brands of motor oils from dino to full synthetic including Motul ester based motor oil. The crankshafts where all submerged for one hour, they where removed then where left outside in the elements for one month.
Only did the Motul ester based motor oil crankshaft did not rust. This was due to the polar bonding for the motor oil onto the crankshaft.
winston
Old Oct 19, 2005 | 09:57 PM
  #59
slickevo18's Avatar
royal purple 10-30
Old Oct 19, 2005 | 10:03 PM
  #60
vboy425's Avatar
mobil One synthetic is the best
