spark plug change messed up!
Old Nov 9, 2005 | 07:46 PM
wingnut's Avatar
Just got a set of BPR7EIX's. Checked the gap... 0.032.
Now what? Everyone says not to touch the Iridiums. Run them at .032?
Old Nov 9, 2005 | 08:40 PM
LIFER's Avatar
Originally Posted by gb_junkie
i took them out, checked them...they all seemed fine. put the stock ones back in...hooked everything up (correctly)..same problem. but i did notice that one of the screws on the maroon engine cover has a crack around it...spewing oil all over the black "mitsubishi" cover when idling. i have no idea how that crack got there.
Welp you better have $330 laying around because you cracked you valve cover.. They are magnesium so almost no-one can repair them.
Old Nov 10, 2005 | 04:24 AM
EVO8LTW's Avatar
No reason to touch those bolts for a plug install. Have the cams been changed?
