ACT or Exedy organic single
Old Oct 31, 2005 | 11:32 AM
rsboy's Avatar
ACT with Fidanza is also a great setup. Drove one and I really liked it.
Does the Exedy single come with a flywheel or no? I'm assuming not for the price, but has anyone have experience with the Exedy single and Fidanza flywheel?
Please post.
Old Oct 31, 2005 | 11:36 AM
ACTman's Avatar
Originally Posted by Monkey
I believe the rpm lockout to be adjustment issue, not product issue. I don't see how the ceremetallic would hold more. It is my understanding it has a quicker wear life than normal organic
A good quality cerametallic will hold about 25-30% more torque because of the extra friction, with the tradeoffs of rougher engagement and possibly increased wear on the mating surfaces. I wouldn't say quicker wear life, but increased wear on the flywheel and pressure plate and probably less on the disc.
Old Oct 31, 2005 | 12:59 PM
Gruppe-S's Avatar
We have found that the Exedy stage 2 with a CCI flywheel work great together. With that said, I am not sure how long it will last since none of my customer has more than 10k on that clutch yet.
From my past experience, ACT makes good clutches but the pedal feel is just too harsh for me.
Thanks,
Tom
Old Oct 31, 2005 | 01:08 PM
mchuang's Avatar
I know on gen 2's act clutch with their hard thick pressure plate forks caused most of crankwalk...4 of my friends all gen 2 turbo had act and they all had crank walk lol..Maybe the motor had something to do with it also but I have never seen one crankwalk on stock clutch..Maybe that isnt the case anymore..Has there been any redesigns on the act clutch or does it still have thick clutch forks?
Old Oct 31, 2005 | 02:06 PM
ACTman's Avatar
I assume you are talking about the 2G DSM. The EVO is quite a bit different. We haven't made any changes to this point on the DSM clutch, but we are considering it for next year now that we have expanded our capabilities. I have heard of crankwalk on stock clutches and even automatics believe it or not. It is definitely an engine thing, but certainly a heavy clutch is only going to make it worse, especially during extended high rpm launches, etc where the engine is spinning real fast under high thrust loads.
Old Oct 31, 2005 | 03:13 PM
Monkey's Avatar
Thanks,
Tom
About how much tq can the stage 2 cerametallic hold?
With the CCI flywhee, is it too light where you need to double clutch on up-shifts? That is one thing I am worried about with a lighter flywheel. I don't want the revs falling off so quick that I have to either power shift all the time or double clutch on upshifts.
Old Oct 31, 2005 | 03:22 PM
mchuang's Avatar
Thx for clearing that up because I do own an evo was really interested in an organic clutch that can at least hold 400 tq..is the clutch the same as far as design for evo and dsm or different?..also what is quite a bit different on the evo??
Old Nov 1, 2005 | 11:16 AM
Monkey's Avatar
bump for torque holding capacity of the cerametallic
Old Nov 1, 2005 | 05:45 PM
Monkey's Avatar
Bump for new clutch. What about the new RPS clutch that is in the same class as the first two?
http://www.injectedperformance.com/V...t.aspx?ID=1304
Old Nov 2, 2005 | 12:17 PM
Spooldyou's Avatar
what about the RRE Dont they offer a nice setup too, and why not shave down the stock flywheel and make due with that ? No a good idea either?
How about a custom setup with a ACT or Clutnet clutch? I have had both with no issues on other cars making more power
I nneedd a clutch REALLLYY bad So any info would help!
Old Nov 5, 2005 | 02:48 PM
ACTman's Avatar
They are totally different in design. The EVO has a pull type 240mm pressure plate while the DSM is a 225mm push type. A pull type system is much more efficient than push type meaning there is less wasted motion due to flex.
Old Nov 6, 2005 | 12:44 AM
mitsuorder's Avatar
I am not trying to argue with you either so please don't take it as such. You were speaking in general terms, not about your car in the post so that is how I took it. Monkey didn't ask if he should buy an organic, but which one. Since you took the liberty to give your opinion on organics, I thought it warranted a rebutal. I don't want to take up any more bandwidth on the subject, but I would like to continue the conversation with you about organics and other materials if you have time. I am going to be out all week at SEMA so maybe when I get back. Drop me an email if you would like to continue or maybe give me a phone number.
No argument, just giving another member some advice from my past experiences. I've used the product and was just letting him know that there is a reasonably priced and superior alternative to organic.
Old Nov 6, 2005 | 01:27 AM
mchuang's Avatar
which is harder on tranny push or pull
Old Nov 6, 2005 | 09:17 PM
ACTman's Avatar
No real difference IMO. They are performing the same task. The difference comes with how much power it can hold (or transfer to the trans) and how harsh the clutch engages which is controlled more by the disc than anything else. Harsh engagement will transfer the power over a shorter period of time which is more like an impact than just torque transfer. Obviously impact plus torque can damage parts more than just torque alone.
Aby@MIL.SPEC
May 18, 2016 05:39 PM
m4tt VIII
12
Apr 5, 2010 11:16 PM
EvolutionBoy67
17
May 5, 2007 07:13 AM
alby988
11
Mar 22, 2006 04:32 AM
ev08buoy
17
Sep 3, 2005 03:17 PM
