which clutch/flywheel would you recommend for my daily driver
Old Mar 21, 2006 | 06:39 AM
alby988's Avatar
my evo when finished will have about 350 to the wheels and my stock clutch is slipping. my evo is my daily driver and i need a recommendation on a clutch and flywheel set. i will be doin some autocrossing and track days as well. I have heard good and bad of the ACT single clutch and flywheel but also heard at the same time that the ACT clutch ruins your synchros over time. Does anyone use the exedy sport or the gikon os? i feel like there are only biased reviews out there. I would get the ACT but dont know about the synchro situation and no one has reviewd the exedy sport. Also, along with the clutch, please give me a suggestion on flywheel too. i do not understand what the difference is between flywheels such as the lbs. and stuff.
thanks in advance
Old Mar 21, 2006 | 08:01 AM
broddey's Avatar
RPS Carbon Carbon.....lots of money, but its cheap to rebuild, no difference in pedal feel, and grabs better and better the hotter it gets!
Old Mar 21, 2006 | 10:27 AM
Eclipsed Evo's Avatar
Been using the Clutch master Stage 3 for over a year without any problems. Pretty close to stock feel and its been holding 400whp daily for about 17k miles. I'm also using the Fidanza flywheel with this setup.
Old Mar 21, 2006 | 02:40 PM
DaWorstPlaya's Avatar
Get the ACT clutch and maybe a fidanza flywheel combo. If you want to save a few $$ just resurface the stock flywheel. The ACT doesn't wear out your synchros, its usually poor shifting by the driver. If your ACT clutch pedal is adjusted properly after the install if will be fine. The problem is, people install the clutch and don't adjust their pedal and when they press the clutch in, it doesn't fully disengage from the flywheel, which in turn makes shifting harder and puts a strain on your synchros. This is true for any clutch.
Old Mar 21, 2006 | 02:44 PM
Danny23's Avatar
EXCEDY HD TWIN, comes with the flywheel
Old Mar 21, 2006 | 02:47 PM
evo-boy's Avatar
go with the ACT clutch its not much stiffer than stock feel
Old Mar 21, 2006 | 02:52 PM
shiftdsm E's Avatar
act street
Old Mar 21, 2006 | 03:20 PM
dubbleugly01's Avatar
ACT street clutch. For your power level, anything more than a street disc (organic) will give up some driveability (and longevity) for holding power that you won't necessarily need or use.
Old Mar 21, 2006 | 03:37 PM
Speed Element's Avatar
Exedy Twin Plate SD or HD
Old Mar 21, 2006 | 07:42 PM
ACTman's Avatar
My opinion of course would be bias, but here is probably the largest poll (over 230 people) with similar question:
https://www.evolutionm.net/forums/sh...d.php?t=126768
Old Mar 22, 2006 | 04:29 AM
kekek's Avatar
I'm very happy with my ACT HD clutch/Prolite flywheel so far. ProStreet had some sick pricing on it. Similar power level and no shifting issues.
Old Mar 22, 2006 | 04:32 AM
TxEvo8's Avatar
I have the ACT as well, 32k, 300 awhp and loving it! The pedal pressure is awesome.
thadon84
38
Aug 23, 2016 12:35 PM
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
Ayrton Senna
Feb 4, 2014 12:25 PM
freakitgood
18
Jul 29, 2008 02:50 PM
dank311
13
Apr 10, 2008 02:16 PM
