Flashers/Tuners/Gurus - Pump gas boost opinions
Originally Posted by Precision Dyno
This thread has become completely useless now.
You have done nothing but compare yourself to every other person on this board. Sorry man, but you need to stop while you are ahead.
No more from us in this thread, have fun.
Also, I still have yet to see any results from the cars you have tuned other than the one with the AEM EMS, which doesn't paint a good picture. I was hoping for some of these other "powerful" cars to provide some empirical evidence to support this notion of running higher boost on pump gas as being a superior method...
His car is also making more power than the Precision-tuned Evo with AEM EMS, cams, injectors, and FMIC...and this is with bad driving (12.6 @ 113.9)....
Trap speeds on an evo can be very confusing and higher trap speeds ALWAYS come with worse driving/launches. Seeing as your buddy is a "bad driver", he is probably seeing extra MPH from that. Cut a nasty launch and powershift and his MPH WILL drop
Although this is a good topic, it has countless variables, and all comes down to tuning. Tuning isn't something that can be read and learned in a thread. Its something that is taught (first hand being best) and comes also with experience...
I'd reccomend anyone wanting to know more to check out "efi101.com". Ben Strader is the man
Using my car as an example, on a 1.92 60', I hit 112.4 after spinning all the way through first and chirping 2nd. I then hit a 1.85 60' while spinning but not quite as bad, but trapped 112.6. I then got a 1.75 60' without spinning or bogging and trapped 113.2. Instead of wasting my time spinning, I was accelerating the entire time, so you definitely can't say that my buddy's "bad driving" is giving extra mph. His 60' on this was a 1.86 or so. If he cuts a 1.6 or 1.7, he's still going to be right around 113-114mph.
Whether I hit a 12.0 or 12.4, my highest trap speed is 113.2. I think it's safe to say the car trapping 113.9 with lesser driving is making more power. Likewise, a car that has run 12.2 at 112-113 at multiple tracks is making no more power than I am and probably less than my buddy. I have also run at the same track as this EVO-NY car (E-town) and hit the same type of times I hit locally, so that part of the comparison is valid, too.
At the risk of muddying the water here a little bit (and keeping things on-topic
), I took a look at my logs from last night. Unfortunately I logged only 2 runs from the emanage (I use a pocketlogger for timing) and one of the logs has bad data in it (it does that sometimes...) and the other I hit boost cut in. The pull with boost cut in the middle went from 2895rpm to 7400rpm, peaked at 23psi and fell to 19.5psi, and had an a/f of 12:1 dropping smoothly to 10.8:1 at 7400. Timing peaked at 20*. The car feels much smoother up top now (not necessarily more powerful - yet) and I did drop the boost some before making that pull, since I had hit boost cut a couple of times an hour earlier. I will keep logging and tweaking though.
This thread is really nothing more then an attempt by Warrtalon to get a tuner to provide him an education in tuning, which one thread is not going to do it.
I have no problem with anyone tuning thier own car but if you chose to do so then maybe you should seek out an education like EFI university instead of just jumping in every tuners thread on this board trying to get the same quality information you could obtain on your own if you chose to.
It's funny someone mentioned Ben Strader in this thread because while I was in Vegas this week I was introduced to Ben Strader by Nick from Precision Dyno.
metaphysical
87
Apr 9, 2008 06:22 AM
