Intake Manifolds?
Old Nov 2, 2005 | 07:49 AM
blk4g63's Avatar
Intake Manifolds?
I cant really decide whether to go with a Magnus Intake manifold or a Weapon R intake manifold. Any ideas?
Old Nov 2, 2005 | 08:53 AM
Ted B's Avatar
That depends. Which GT series turbo are you running?
Old Nov 2, 2005 | 09:44 AM
CBRE's Avatar
AMS manifold, get the best and be done with it.
Old Nov 2, 2005 | 09:52 AM
djskyy's Avatar
yeap, the AMS intake manifold is pretty badazz....you should see it in person to realize how nice & big this badboy is...a must have if you're running a large turbo....
Old Nov 2, 2005 | 10:05 AM
en1gma19's Avatar
AMS is the manifold to have. Don't kid yourself, anything else is small potatos.
Old Nov 2, 2005 | 11:55 AM
HB4's Avatar
HB4
Ams is good but RnR is good also!!!
Old Nov 2, 2005 | 12:08 PM
sayanara's Avatar
What makes the AMS manifold the best? It is priced competitively. Nobody has mentioned the JUN or the Kansai manifolds.
Old Nov 2, 2005 | 01:52 PM
dan628's Avatar
How much, if any, would the AMS manifold help with the stock turbo?
Old Nov 2, 2005 | 02:05 PM
evolgrl's Avatar
Magnus is the best time tested 1g and 2g.
Old Nov 2, 2005 | 02:11 PM
gt40's Avatar
I like my bjcs intake manifold...
Old Nov 2, 2005 | 03:11 PM
IEXCELR8's Avatar
Gains on the stock turbo will be anywhere from 10-20hp. A larger turboor stroker will give another 15-20hp. Also you would realize quicker spool and throttle response.
If on the stock turbo I would get the busher ported IM and Tb.
Old Nov 2, 2005 | 03:43 PM
Ted B's Avatar
FWIW, the only tests I seem to recall clearly showed *slower* spool characteristics with the typical aftermarket intakes (probably due to the short runner length), and verifiable improvements only at very high rpm.
Old Nov 3, 2005 | 12:12 PM
RnR Racing's Avatar
We have 2 different Intake Manifolds for the EVO. We have our 2.0 manifold an our 2.3/2.4 manifold. I would put ours up against anything else on the market as far as strength,reliability, power, fitment, etc. I do believe we are the only company that welds on our Intake manifolds on the inside for added strength an reliability.
Old Nov 5, 2005 | 05:24 PM
silverlining's Avatar
So if I am running w/ ecutek, mbc and a tbe on the stock turbo, a manifold/tb doesn't need to be a top priority? I want to do cams soon, but saw a possible deal on a manifold. Should I wait till I upgrade to a larger turbo?
Old Nov 5, 2005 | 05:26 PM
Ted B's Avatar
An aftermarket intake a priority? No, not even with a larger turbo.
