alternate locations for alky control unit
Old Nov 11, 2005 | 05:02 AM
EVO8LTW's Avatar
Other than right below the lower DIN slot or the change cubby, where have others mounted the SMC alky control unit?
Old Nov 11, 2005 | 06:38 AM
PPI's Avatar
PPI
yeah, i couldn't find a great spot for mine....so put them in the cubby under the ventilation controls....used some really strong velcro on the top of the boxes and stuck them both to the "roof" in the cubby spot. had to cut a hole in the back to slip both boxes in... but i am really happy with them there as they are easy to access for me. if you put them somewhere else post up some piqs when your done!
Old May 8, 2007 | 03:14 AM
cij911's Avatar
Bump for more mounting locations for the SMC unit...
Old May 8, 2007 | 03:19 AM
JordanS4's Avatar
Mine is mounted to the back of the glove box if you want pics I can take them later today.
Old May 8, 2007 | 03:21 AM
JordanS4's Avatar
By the way Rich this is Black Magic MR from DCEvo
Old May 8, 2007 | 03:40 AM
cij911's Avatar
If you could take / post a picture that would be great....How do you monitor the LEDs?
Old May 8, 2007 | 03:45 AM
JordanS4's Avatar
There is only one status LED which I check regularly, but the failsafes are built into the ECU and I will know right away if something goes wrong because it will switch to the low octane map which is tuned to run without alky safely. Ill get pics up for you later today.
Old May 8, 2007 | 03:57 AM
cij911's Avatar
How have you setup the ECU to use 100% Low Octane map? The ECU generally targets a mix of High / Low maps based upon Knock and Octane Value. If you have a way to switch over to 100% Low upon an event (Knock, AFR, etc.) I would LOVE to know how you mod'd your ECU. Thanks
Old May 8, 2007 | 11:14 AM
cij911's Avatar
Bump for ideas / pictures on where to mount the SMC controller....Thanks
Old May 8, 2007 | 11:45 AM
EVO8LTW's Avatar
This is a 2005 thread! I've since installed, removed and sold my SMC kit. I think the change compartment is pretty ideal from the standpoint of convenience and wiring.
Old May 8, 2007 | 11:55 AM
8thWonder's Avatar
I said the same thing! I wondered if you even still had the car!
Old May 8, 2007 | 11:59 AM
cij911's Avatar
2006 MRs don't have the change drawer ....The ashtray looks too small / narrow, although I guess something could be custom developed...Also funny how one gets slammed for searching and adding onto a relevant post ...
Old May 8, 2007 | 03:44 PM
chaotichoax's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=192006
