New Clutch...expect harder shifting?
Old Nov 11, 2005 | 04:22 PM
Sap12687's Avatar
Ive had my Clutchnet sprung-hub 6-puck w/ their race pp in for about 500 miles now and shifting is still difficult at times, especially downshifting into low gear at low rpm's. Is this to be expected with a non-organic clutch?
Old Nov 11, 2005 | 04:29 PM
ACTman's Avatar
Try adjusting the clutch for a bit higher release/engagement point and see if that makes an improvement.
Old Nov 11, 2005 | 04:33 PM
Sap12687's Avatar
you mean so the clutch engages higher?
Old Nov 11, 2005 | 08:33 PM
Sap12687's Avatar
bump
Old Nov 11, 2005 | 09:10 PM
ACTman's Avatar
Yes. Adjustment is covered all over the board. Here is a couple links that might help.
http://www.roadraceengineering.com/e...utchadjust.htm
http://www.evomoto.com/tech_info.php?tech_id=28.
Old Nov 11, 2005 | 09:27 PM
Deepseadiver's Avatar
Thanks for the links. Now I need to get under there and check things out. I have heard that a little turn goes a long way.
Old Nov 11, 2005 | 09:31 PM
ACTman's Avatar
You can adjust it as far as you like as long as you don't preload the system. There has to be at least a slight amount of freeplay on the rod.
josh_evo9
14
Oct 24, 2016 11:58 AM
oozkarao
Oct 4, 2011 01:25 AM
Don Q
Feb 18, 2011 12:26 PM
TurbotrixRacing
30
Mar 17, 2008 09:06 PM
EvoRs
10
Nov 9, 2004 12:58 PM
