set-up
set-up
What does everyone think about this set-up? Any Comments would be appreciated.
S.S. Turbo Outlet
Megan Racing S.S. Tubular manifold
either LPI or Turbo XS S.S. Catback
K&N drop in filter
AMS fuel rail
Walbro Fuel pump
Aeromotive Fuel Pressure Regulator
AEM cam gears
LPI underdrive pulley
HKS 272 intake and exhaust
AEM EMS
S.S. Turbo Outlet
K&N drop in filter
AMS fuel rail
Walbro Fuel pump
AEM cam gears
AEM EMS
Sounds fine.
Do the LPI or Megan, not the TXS exhaust.
Not sure if you need the fuel rail or FPR on the stock turbo. Why do you want those?
Don't do an underdrive pulley - instead, do an LICP.
Are you sure you want an AEM EMS? It will require a ton of tuning knowledge, is very expensive, is not needed for the stock turbo, and will require a lot of maintenance.
Originally Posted by adorkableVo
burchur is going to be the one tuning for me
setuo
I wouldnt bother with upgrading the fuel system... I made 412 Hp on the stock fuel system stock turbo AFC and 272's with race gas and 380 on pump! Stock fuel system is underated by a lot of people
It is a good idea,he is wrong but it is very expensive and the same goes for tuning it,I tuned mine my self but i have went to automotive school for nearly ten years.just get a flash on your stock turbine,
You really dont need the fuel rail or aeromotive fpr right now. The AEM EMS is a little over kill for that setup, but if you know your way around fuel and ignition maps its a good investment for your future mods, ie bigger injectors, turbos. Not to mention I really like the speed density setup.
Dont throw too many things at once, because it gets harder and harder to find the bugs.
Bigger turbo will come later. Maybe next winter. Everything I listed above, I plan on buying this winter or spring.
I forgot to add, I plan on buying 1000c.c. injectors. Thanks guys for all the comments.
