How does a BOV work?
Old Nov 22, 2005 | 10:03 AM
zze86's Avatar
yes another BOV thread but a little different. I'm new to turbos and understand the basics in what one does but I'm more interested in how one actually works.
We'll take an APS BOV for an example.
This is what I think is happening, please correct me if I'm wrong. Inside the casing there is a metal shaft that blocks off air from escaping. Seated on the metal shaft is a spring, whose tension can be adjusted with the screw. There is also a "vaccum" nipple on the end there that you cannot see. That "vaccum" nipple also helps create pressure on the backside of the metal plate to help the spring(?)
When you release the throttle, the throttle plate swings shut, all that built up air is looking to go somewhere. That little "vaccuum" nipple also is no longer producing pressure but is now in vaccum mode, or sucking the metal plate against the spring. That sucking combined with the built up pressure overcomes the spring pressure and allows the BOV to vent, wether it be to the air or back into the intake tube.
Again please correct me where I'm wrong.
Thanks in advance!
-Chee
Old Nov 22, 2005 | 10:30 AM
dubbleugly01's Avatar
you are correct in a nutshell
Old Nov 22, 2005 | 10:51 AM
05SilverEvoVIII's Avatar
Agreed +1
Old Nov 22, 2005 | 02:48 PM
ez's Avatar
ez
Here you go!
https://www.evolutionm.net/forums/sh...ad.php?t=24611
Thanks in advance!
-Chee
Old Nov 22, 2005 | 02:51 PM
zze86's Avatar
gracias mi amigos!
Old Nov 22, 2005 | 04:10 PM
ez's Avatar
ez
De nada!
gracias mi amigos!
DaGermanEvo9
19
Nov 29, 2010 12:49 AM
1991lx50
Nov 20, 2010 01:28 PM
Clipse3GT
18
Dec 16, 2009 02:48 PM
mscorei
20
Mar 5, 2008 06:45 PM
KevinD
11
Oct 4, 2006 06:18 AM
