Case Study # 112 - Why I love Buschur Racing Parts !
Old Nov 22, 2005 | 11:28 AM
DynoFlash's Avatar
Here is a 2005 Evo with a
Buschur Air Filter - no mass air pipe
3" exhuast
264 cams
Forge MBC
Walbro pump
Custom Dyno Flash tune
22 psi peak falling to 20
93 Octane fuel
Note how well the Buschur Air filter works in metering the air flow. The a/f curve is like a flat line.
The changes needed from my mail in tune were so slight that a custom tune was virtually uneeded.
The simple, inexpensive, USA made Buschur Racing parts work well, out perform JDM parts which cost much more and they are simple to install
Attached Thumbnails Case Study # 112 - Why I love Buschur Racing Parts !-mrbr111.jpg
Old Nov 22, 2005 | 11:55 AM
yellowEVO21's Avatar
wow, nice graph
Old Nov 22, 2005 | 11:58 AM
brodienuchies's Avatar
THOSE are good numbers...nice!!!
Old Nov 22, 2005 | 11:59 AM
Genesis8's Avatar
Must be the 05's...
Old Nov 22, 2005 | 12:01 PM
DynoFlash's Avatar
The 05 is a better turbo
My thought is that the IX turbo will be the best
Old Nov 22, 2005 | 12:41 PM
zze86's Avatar
What do you mean by this? The burshur kit I see still uses the stock MAS
Old Nov 22, 2005 | 12:47 PM
DynoFlash's Avatar
There are TWO levels of buschur intake
One is just the filter itself as in this car
the SECOND level replaces tha stock black accoridan like hose piece with a astraight stainless steel pipe
I was trying to point out that thsi car has stock mass air pipe and stock fmic pipes
Old Nov 22, 2005 | 12:58 PM
zze86's Avatar
ah, yes, I missed that 2nd intake combo option on their site.
Old Nov 22, 2005 | 02:41 PM
4-BNGR's Avatar
3" exhuast
264 cams
Forge MBC
Walbro pump
93 Octane fuel
What is the diff between the BR air filter and any other "cone" type filter on the market? Or generally, do you mean that you approve of "cone" type filters over the 1) stock box, 2) Suction Type, 3) etc...
Plus Buschur's filter is one of the oldest on the market - therefore not built around tuning, per se, but vice versa.
Old Nov 22, 2005 | 03:59 PM
Chris@nolimitmotors's Avatar
buschur makes his own filter??? like he actually makes the material??? are you saying that if a K&n filter or AEM filter or injen filter was used the results would different?
Old Nov 22, 2005 | 04:13 PM
broeli's Avatar
What brand are the 264 cams?
Old Nov 22, 2005 | 04:27 PM
DynoFlash's Avatar
I have found over 2 1/2 years of evo experience that the Buschur Air intake is deadly consistant and accurate in the way it flows air into the maf sensor
I have seen other intakes which throw off the maf reading
I personally am happy when ever I see a car which has the Buschur intake on it - it means that its an easy car to tune and it will make great power
Old Nov 22, 2005 | 04:28 PM
DynoFlash's Avatar
I dont know - I will check that and report back
Old Nov 22, 2005 | 05:12 PM
SlowCar's Avatar
Old Nov 22, 2005 | 05:24 PM
sleet's Avatar
Nice numbers indeed
