my clutch
Old Dec 1, 2005 | 06:42 PM
farhans evoviii's Avatar
my clutch
I have a stock evo 8 and i was driving bringing my car upto about 5000rpm and i was shifting from third to fourth and after i put it into fourth my car made a weird scratching noise so i pushed the clutch back down to take it out of gear and my clutch just fell so i picked it up with my hand and it wouldnt go back down. so i got my car towed to the dealer ship and they said are charging me over 1000 to get it fixed should i just put an after market clutch instead of the same factory clutch? if so what type?
Old Dec 1, 2005 | 06:55 PM
navysevo's Avatar
find out exactly is wrong. seems like more than a clutch to me..but anyway if you have mods or plan on getting mods you should definately get a better aftermarket clutch it will cost you less or maybe a little more depending on how much you wanna spend the average labor at a shop for a clutch install is 600.00 to 800.00. the clutch can be bought for less than 500.00 shipped. or if you going with more mods get a better clutch 1200-2800..your choice but i would never pay to put a stock clutch back in that just retarted even if your evo is stock.
Old Dec 1, 2005 | 07:32 PM
BURNALL_4's Avatar
ok the clutch is considered a "wear" item is it is not covered buy the manufacturer. so there are pros and cons to this.
pro: you can put in whatever the hell you want to and they cant tell you other wise.
con: you have to buy the part and pay the labor to have it put in which is maga $
like the guy above said how much do you wanna spent 500-600 single disk (ACT is good)or 1000-3000 multi disk (EXETY, RPS)
Old Dec 1, 2005 | 08:33 PM
ACTman's Avatar
It sounds to me like the release bearing came off the pressure plate.
Old Dec 1, 2005 | 08:56 PM
dubbleugly01's Avatar
be careful here, the clutch doesn't sound bad by your description, it sounds like a mechanical failure of sorts. The clutch disc facing is considered a wear item, and is not covered by warranty, but the release bearing is NOT called out. So, if you have a mechancial failure of the release bearing or any other component other than "clutch disc facing wear", and everything is stock, I think you have a very good argument to have it fixed under warranty.
Old Dec 1, 2005 | 09:35 PM
ACTman's Avatar
I agree.
sleet's Avatar
You might want to edit out the racing part being how it's not allowed on these forums.
Old Dec 1, 2005 | 10:01 PM
SEEYA's Avatar
he doesn't where, could have at the track...
Old Dec 6, 2005 | 01:35 PM
lemansz's Avatar
a friend of mine has a twin disc carbon, i was very impress4ed with its operation.
AJ18
Feb 4, 2017 07:16 AM
thadon84
38
Aug 23, 2016 12:35 PM
shotgun_joshy
Jan 2, 2011 11:42 AM
damien ramirez
Sep 29, 2005 01:44 PM
jlanceroz
Driving Techniques
Nov 4, 2002 07:26 AM
