Bad vibration!!
Old Dec 4, 2005 | 07:02 AM
LIFER's Avatar
Originally Posted by ACTman
Here are my thoughts:
Since it is rpm related, I am curious if it is flywheel or clutch related. Those are the items that cause the most primary vibration. What flywheel are you using? Could the flywheel be coming loose. If so, the vibration might get better as you push on the clutch pedal. It is really hard to get the pressure plate to come apart and cause vibration, but maybe the disc is coming apart? Have you had any noticable difference in pedal feel? Does it happen whether or not the clutch is engaged or disengaged? In other words, if you have the car in gear and clutch pedal down (disengaged clutch) does it still vibrate? If so then it is probably not the disc, since the disc is not spinning at that time. You also said "loud noise" which makes me think release bearing problem, but generally vibration doesn't accompany a release bearing problem. Does it feel rough like a bad bearing or does it shake like a balance problem? I hope you figure it out!
That was my first thought so I dropped the tranny and everything was fine, even replaced the TOB...Still had the problem..
It does it everytime my car hit about 3k rpms and over, if im not moving or if I am, If the clutch is in or out.
Old Jan 8, 2006 | 12:20 AM
elhalisf's Avatar
did u ever figure out this problem? could it be something to do with the balance shafts?
Old Jan 8, 2006 | 12:22 AM
LIFER's Avatar
yea it ended up being spun bearing's and a bent crank
Old Jan 8, 2006 | 12:23 AM
elhalisf's Avatar
ohh ya, i remember u mentioning that. any idea how that coulda happened?
hows the car running now?
Old Jan 8, 2006 | 12:31 AM
LIFER's Avatar
Im rebuilding it now, probably from 30psi on a stock turbo... lol
Old Jan 8, 2006 | 12:36 AM
elhalisf's Avatar
OUCH!
wouldn't you think it would take out the pistons first, before the crank? i mean these cranks can handle 800whp!!!
if you need any parts, i have a complete bottom end.
for me, i bought the crashed evo with a cracked block. the crack went from one end of the cylinder to the other. had to rebuild mine as well.
Old Oct 4, 2021 | 10:40 PM
Alexis Corchado's Avatar
I know this is a long time ago but I might have the same issue. I delete balance shaft and install a harmonic damper and still the vibration.
my second choice is change flywheel and clutch to see if it goes away. And now I read this post and Im crying right now🤣😭🤣😭🤦‍♂️
ct63084
Jan 11, 2016 01:56 PM
seiya
Lancer Engine Management / Tuning Forums
Jul 26, 2012 09:43 AM
Tw3NTy0n3
38
Jun 15, 2012 07:46 PM
domantas
Jul 4, 2010 11:42 PM
Derek888
35
Dec 22, 2005 02:12 AM
