Few important Questions regarding GT35R
Old Dec 4, 2005 | 09:17 AM
EricJ@AMS's Avatar
Originally Posted by smokedmustang
Thanks Whoosh, thats the answers Im looking for. I was told by the SAAB guy that the cartridges on the ball-bearing turbos must be "freshened" yearly, at a cost of 750+ dollars. He steered me away from one of those turbos when i wanted one for my 88 SPG 900 Turbo (long time ago). I was just curious if this was still an issue? No one heard of this?
That is the most ludacris thing I've ever heard. The Garret ball bearing CHRA is probably the toughest and most dependable center section I've come across in my entire life. I bet these turbos will outlast anything made. I've seen more stock Evo 8 turbos fail than GT35R's.
Old Dec 4, 2005 | 10:57 AM
smokedmustang's Avatar
Ok OK. That is why I posed this question. this was in '98 or so I was told this. I will take your word on that, as noone else came up to confirm or deny it. Thanks.
Old Dec 4, 2005 | 12:43 PM
nickracer9's Avatar
I have the fullrace stuff and it is top notch. things to look for in turbo kits are the shape of the collector and the downpipe. most kits out there lack in this area. I've never heard of a fullrace mani ever cracking also.
Old Dec 4, 2005 | 12:52 PM
Thanks nick!
Old Dec 4, 2005 | 02:38 PM
Geoff Raicer's Avatar
1. Do the tubular manifolds tend to crack more if used on a daily driver?
1. Cracking is an issue only with poorly constructed and poorly designed manifolds. A high quality thickwall manifold has the ability to outlast your car. One thing to keep in mind is that not all tubular manifolds will perform equally, there are many designs considerations to take into account.
2. Do you have to "freshen" the cartridge yearly? (I heard about this by a SAAB turbo guru.)
2. your SAAB turbo guru is probably used to older style bushing journal turbos like Turbonetics or some off-name brand. The garrett GT series turbos are extremely high quality and exceptionally durable. There will is no need to freshen this turbo unless you have catastrophic failure.
3. Are there many with a GT35R setup running stock head and internals (besides the ARP rod bolts?)
Yes, it works quite well. Upgraded camshafts are an excellent idea.
4. I believe if you go this route (GT35R) you need a new down-pipe to fit.
4. new manifold, new downpipe, new wastegate
5. Is using a 35-50 shot of nitrous more effective when needing quicker spool-up while racing, or is a Stroker-kit more economical. For those of us who use it for daily driving as well?
5. no need to aid spool if the turbo kit is setup properly. A good Gt35R turbo kit will spool VERY quickly. A stroker kit is the best way to spool a turbo faster, however this is not cheap.
6. I am guessing the most "popular" kit bought is the AMS one. Anyone want to report how they like their RNR/Bushur/Other GT35R kits. I think the only difference is the manifold correct? a GT35 is the same, it just differs on what it "hangs" off of.
6. check my sig
link to our stage 3 GT (gt35R) evo turbo kit
http://www.full-race.com/catalog/pro...roducts_id=740
Old Dec 4, 2005 | 02:47 PM
Originally Posted by Whoosh
the GT35R is a high pressure turbo. It really does not start making good numbers until at least 25 ... c16 and a little spray at the strip you can run 30 psi and more timing and feel the REAL power of a 35R.
I actually disagree slightly with this. The GT35R is definately very efficient at high boost levels, however it also works extremely well at low boost levels, too. We have seen cars make great power from 10 psi to 35 psi.
Also, if you are looking to make more power at all boost levels, we offer an exclusive turbo called the FR GT3567R. This is a gt35R center section, turbine wheel and housing with a T67 compressor wheel. This combination spools like a GT35R but makes the power of our T3/T67 HO.
One more note, if the turbo/engine are setup perfectly, with a good intake manifold (unfortunately i havent seen many of these yet) and properly degreed cams/cam gears, you can make HUGE power with very little timing. The less timing the better, as cylinder pressure is what destroys motors.
If the car is built perfectly, adding timing does not make more power, it simply increases cylinder pressure (hurts the motor). C16 is a great idea at high boost, regardless of timing, but in all actuality, if the car is perfectly tuned, more timing will not make more power.
Old Dec 4, 2005 | 03:20 PM
Thankd Geoff, nobody needs to post anymore info! this sums it up. I did go look at your website, and I must say, I havent heard of you till today, you have an awesome looking setup there!!!Thanks for your input.
Old Dec 4, 2005 | 03:29 PM
Smogrunner's Avatar
5. Is using a 35-50 shot of nitrous more effective when needing quicker spool-up while racing, or is a Stroker-kit more economical. For those of us who use it for daily driving ...
Answers:
3. Yes, me, except I run HKS 272 cams.
5. Obviously, the stroker kit is way better for daily driving than Nitrous. However, it didn't seem economical to me. I'm still recovering financially from the build.
Old Dec 4, 2005 | 03:37 PM
Originally Posted by Smogrunner
Answers:
Hey Smogger,
Good to see you are still around, I thought you got rid of your evo. I dont think the stroker would be worth it, but then again, maybe its time to freshen the pistons, as I am close to 55K miles now. dont know which way to go if I track it monthly, and street drive the rest. I am not looking to Drag, just roadcourses. Thanks for the input!
Old Dec 4, 2005 | 08:30 PM
DawnoffateX's Avatar
Full Race kit is rather nice. However, can you select certain parts? Or are you obliged to buy whole kit?
Also, how streetable is the gt35, and how much of a risk does it pose to stock internals on pump?
Old Dec 4, 2005 | 08:52 PM
nickracer9's Avatar
you can buy individual parts also.the 35r is very streetable, nothing like i though it would be. I will never go back thats for sure!
Old Dec 5, 2005 | 05:26 AM
Whoosh's Avatar
Not to be a d---, but if you can show me an Evo with a GT35R making "great power" at 10 psi, I'll eat the whole car bumper to bumper.
I run a very conservative "street tune". I'm not sure what you consider a "perfect setup" but I will tell you that when I go to the strip and run c16, I can add timing and make more power.
Old Dec 5, 2005 | 07:17 AM
EricJ@AMS's Avatar
What turbo IS going to make great power at 10 psi?
Old Dec 5, 2005 | 08:17 AM
Whoosh's Avatar
I'm sure there is someplace, but not on an EVO!
Old Dec 5, 2005 | 08:56 AM
rlazer5000's Avatar
Actually Scionspeed threw a GT35 on a Scion tC and made over 300 whp at around 10-12 psi. The car had stock internals and it still managed to run a low 12 second 1/4 mile. But I think they ran it on 16 psi for that run. It's in one of the issues of Modified Mag.
