Anyone have experince with Nitromethane?
Old Dec 5, 2005 | 04:48 PM
joeymia's Avatar
I have some nitro and would like to test how some would work Just wondering if anyone has any experince with this mixed with some methanol. I was thinking about 5-10% nitro.
Old Dec 5, 2005 | 04:50 PM
Juiced's Avatar
FYI nitro won't burn it will explode not to mention the increased flame propogation as well as increased heat and lower AFR's......
In other worrd i don't know but unless you have a bit of money to buy a new motor i wouldn't be the first one to try.
Old Dec 5, 2005 | 05:31 PM
DSMotorsport's Avatar
Personally, I would try it, BUT procede with extreme!!! caution. I would start mixing in like 1% or 2% incrememnts. Im assuming your speaking of running a little nitro in your single jet meth kit in the IC pipe?
Old Dec 5, 2005 | 06:54 PM
joeymia's Avatar
correct.
I was thinking of running a mixture of meth/water/nitro with racegas. I remember reading somewhere that you can mix like 50% water, 45% meth, and 5% nitro. Nitro will seperate from the water/meth if you do not mix it over a certain amount . I'll probally test with a few mixtures to make sure 5% will not seperate. Would hate for the nitro to seperate, sink to the bottom, end up spraying 100% nitro.
I was wondering if anyone has tested this before on the evo.
Old Dec 5, 2005 | 07:00 PM
lemansz's Avatar
GOOOOD GAWD!!
LOL
ima save this thread!
INSTANT EMAIL NOTIFICATION!!!
Old Dec 5, 2005 | 07:21 PM
scott88vr6's Avatar
Originally Posted by lemansz
GOOOOD GAWD!!
LOL
Old Dec 5, 2005 | 07:22 PM
Ultimate CC's Avatar
subscribed as well, good luck with that just be careful
Old Dec 5, 2005 | 07:35 PM
joeymia's Avatar
i asked this question a while back and got some good responses. Forgot it was on this board no wonder I could not find the original thread:
https://www.evolutionm.net/forums/sh...d.php?t=165949
At the time i was affraid of running to lean. With the MAFTpro I can set target AFR's to protect myself from suddenly running lean. I would theorize that I should gain some horsepower running the proper mixture. Won't be safe for everyday use but I fun at the track and safer than nitrous.
I am running BR8EIX plugs right now I wonder if I should get 9's. Screwed my last set of 8's messing with ignition retard on the MSD So I think i'll order a new set tonight.
Old Dec 5, 2005 | 07:47 PM
Smogrunner's Avatar
Sorry about the worthless post here. (something T-Squad is trying to avoid). But this has got to be the best avatar ever!
Oh yeah, interesting topic too. Subscribed.
BTW, this one is tied for second with mine:
Warrtalon has some work to do to play with Malcolm, Richard, and Albert!
Old Dec 5, 2005 | 07:57 PM
TTP Engineering's Avatar
Nitro does not mix with water. Only methanol. Very corrosive to metals. There are other options you can PM me about. I have done quite a bit of research in this area.
Old Dec 5, 2005 | 08:47 PM
joeymia's Avatar
I am my own squad... Truf Squad...
Old Dec 6, 2005 | 08:07 AM
mrcox's Avatar
For Gasoline, people use a product called NITROPROPANE. nitromethane does not mix with gasoline very well.Nitromethane as a fuel additive.
We are sometimes asked about adding nitro to gasoline or methanol. This is possible and it has been done successfully. However, there are a number of problems that make this impractical. These include the corrosive nature of the combustion gasses after nitromethane is burned. This process produces large amounts of nitric acid, which is not only corrosive but toxic. To prevent serious corrosion, a thorough flushing of the fuel system and motor is necessary after use. While it burns slowly, there is also the danger of explosion when nitro is used. Another issue is solubility. If you are running methanol, there is no problem as nitromethane and methanol mix freely. But nitro does not mix easily with gasoline. So, if a nitro/gas mixture is desired additional chemicals must be added to prevent separation.
Nitropropane - an alternative to nitromethane.
Both nitromethane and nitropropane are oxygen-bearing fuels. This means that nitro fuels carry two oxygen atoms as part of their chemical makeup. While nitromethane (CH3NO2) does not mix with gasoline, nitropropane (C3H7NO2) does. This makes it much more practical as an additive. A commercial mixture of nitropropane and antidetonation agents is available under the "Klotz" brand. Mixtures of ~10% nitropropane and gasoline have been tested and shown to provide small but significant power increases. A good writeup on this was published in "Hotrod" and is available online at http://www.hotrod.com/techarticles/42018/ If you decide to try this, you must richen the fuel mixture and even then you can destroy your motor, so try this at your own risk!
http://www.kennedysdynotune.com/Nitr...ech%20Tips.htm
Old Dec 6, 2005 | 08:27 AM
4ringturncoat's Avatar
There is also this as an option. http://www.pricechemical.com/super_concentrate.htm Nitro like any highly oxengenated fuel will require lower afr's. I have no idea how a wideband will react to Nitro. Might be fun to use though.
Old Dec 6, 2005 | 09:23 AM
Boost Freak's Avatar
I run 35% nitro in my RC truck. We had a half-gallon laying around And put it in a mini bike(made for gasoline) And that thing kicked ***. This is about all the testing I have done with it. And if you have steal parts in the engine the methanol in the fuel is a hygroscopic, Which means it easily attracts and absorbs moisture. The moisture could cause rust and corrosion on steel engine parts if the fuel is not removed. I say just stick to good old C-16.
LuDa
Lancer Engine Tech
14
Jul 15, 2008 06:06 AM
joeymia
35
Oct 27, 2007 01:26 PM
Tek3Evo
13
Jul 11, 2005 10:32 PM
cerfur
Jan 19, 2005 04:24 AM
