Yet another problem...
Old Dec 10, 2005 | 08:20 PM
VIIImylunch's Avatar
How many people have had timming belt tensioner issues at 3400 miles?
Old Dec 10, 2005 | 09:41 PM
P_A_STREET_EVO8's Avatar
Just double check all your lines for boost leaks. Also check your fuel pump lines or the fuel pump it self if you dont have one i recomend you get one. You should use a afc or get a reflash to fine tune your timeing i bet your check engine light is on , and it go be going to safe mode if you havent took off the fuel cut. Man the list can go on and on thouses are a few things you should check besides the places your looking at now.
Old Dec 10, 2005 | 09:51 PM
Checked the boost the leaks, they are fixed. I know the cam gear slipped a tooth because I just looked at them and the are no longer alined correctly.
Old Dec 10, 2005 | 10:26 PM
silverofs's Avatar
they don't line up every time around you know that right??? cam gears are so overated it's not funny..the only way you can jump a tooth is your cam gears moving tons or yur belt tension is not correct.. are you running your aem yet??? i can look @ it if your in s.l.c to give you ideas of what is going on.
Old Dec 11, 2005 | 07:55 AM
The car is down in PG. That would be cool if you came down I need some one who has worked on evos before come look at it. I do have the aem, but it isnt in yet. Before I looked at the timming marks on the cam gear I was getting almost zero vacuum.
Old Dec 16, 2005 | 08:14 PM
ok so all the leaks are fixed, and I replaced the plugs. The car still seems to have the same problem it will boost over 20 psi now but as soon as i get into boost the car sort of studders and bogs down. anyone have any idea what this could be?
