ACD Article - Answers for everybody!
Old Dec 17, 2008 | 03:11 AM
  #211
zedevo's Avatar
Guys ... good news for me as for all of u !!!!!!
I had the same issue after checking every thing as Fluid leak, TPS sensor, etc ...
The Problem on my car was the ABS SENSOR '' not the fuse '' I replace it with another one so no more problem with 3lights ....
Cheers
Old Dec 17, 2008 | 07:16 AM
  #212
detroit pistins's Avatar
Cheers
good to hear!
Old Dec 17, 2008 | 08:04 AM
  #213
zedevo's Avatar
Originally Posted by detroit pistins
good to hear!
check urs man ....
Old Dec 17, 2008 | 08:29 AM
  #214
check urs man ....
i took the guy to the dealer, it basiclay needed to be bled, that's why the syste was sucking all the fluids in the reservoir and the level was dropping . but i haven;t bled it yet, however, how many quarts do u think it takes?
Old Dec 17, 2008 | 10:03 AM
  #215
zedevo's Avatar
I didnt get ur point of view dude ...
Old Dec 17, 2008 | 10:41 AM
  #216
what i meant was that my issue was that the fluid level in the acd reservoir was dropping and it would cause the 3 lights to come on. i could not find any leaks in the system, thus, i took it to the dealer and had them look at it. they said that there was no leaks and everything was fine, however, the system needs to be bled because whoever changed the fluid , didn;t bleed the system, and that's why the reservir level keeps on dropping because the acd had an air pocket and keeps on sucking more fluid as the pockets shifts around. that's what they said, they wanted 100$ to do the bleeding for me so i refused to get it done there (atleast for now, been busy) but iam planning on taking it back to them and have it bled. but my next question is that i have put almost 2 quarts of atf into the reservoir and it does drop in level but not as much as before, minor. so how much does the acd really take in quarts after a fluid change?
Thanks,
btw, i appologize for the missppelings.
Old Jan 22, 2009 | 09:00 PM
  #217
Here are some updates;
the lights could come on for all the reasons that were discussed above except for ONE and that was my case (unfortunatly), lucky me, my car is pretty much bone stock and the warranty is still valid, mitsu tech support got thier hands on it and figured what the problem was. Apparently since the ACD unit is placed inside the transfer case, there is a rubber seal in between those two units, that seal was leaking acd fluid into my tc hence no leaks were found. the dealer basicaly had to replace my TC and now everything is good to go! hopefuly none of u guys would encounter such a thing but if u do, keep this in mind and mention it to the dealer.
Thanks and goodluck.
Old Jan 23, 2009 | 01:17 AM
  #218
zedevo's Avatar
Congrat's man ...
Old Jan 23, 2009 | 05:41 AM
  #219
Congrat's man ...
lol thanks man! it drove me nuts till we figured it out.
did u fix ur car?
Old Jan 23, 2009 | 06:07 AM
  #220
zedevo's Avatar
^^ Yeah man from long time .....
Old Jan 23, 2009 | 06:11 AM
  #221
good good to hear!
Old Feb 18, 2009 | 09:57 PM
  #222
Torque07's Avatar
very nice just answered alot of questions
Old Mar 2, 2009 | 07:08 PM
  #223
envdevo9's Avatar
nice work!
Old Mar 22, 2009 | 08:27 AM
  #224
dank420's Avatar
give info i ve always wonderred how the Acd worked on turns
Old Mar 27, 2009 | 09:07 AM
  #225
dgrumpys's Avatar
Y
GREAT INFO!!!!!!
