how to brake in new engine
Old Dec 22, 2005 | 09:17 AM
yesevo's Avatar
i ve searched but coulnt find any info////
lots of people seems like taking it easy when it comes to brake in period...
but i m not sure about it....
http://www.mototuneusa.com/break_in_secrets.htm
tell me about it~
Old Dec 22, 2005 | 09:19 AM
nutrulz's Avatar
The way stated in the website you posted is for high horse power applications. Longevity might be different.
Old Dec 22, 2005 | 09:24 AM
ThunderOZ's Avatar
u could jst follow the manual...
Old Dec 22, 2005 | 09:25 AM
ThunderOZ's Avatar
boost regularly and jst dont go over 5000rpm
Old Dec 22, 2005 | 10:05 AM
04 rs's Avatar
Everytime ive built a motor this is how i broke it in and never had a problem. Pull the ecu fuse and crank it over for acouple seconds to get the turbo and pump primed. Let it run to operating tempeture check for leaks and if everything is good take it out to the highway. Go into third gear do a couple pulls and let it decel by itself. After doing this the rings should be sealed. Do a compression and leak down test if everything is good drive it however you want as long as its tuned to be that way. Also drain and put new oil in after doing this. Thats what i always did never had one problem
Old Dec 22, 2005 | 10:14 AM
housedj's Avatar
Originally Posted by 04 rs
Everytime ive built a motor this is how i broke it in and never had a problem. Pull the ecu fuse and crank it over for acouple seconds to get the turbo and pump primed. Let it run to operating tempeture check for leaks and if everything is good take it out to the highway. Go into third gear do a couple pulls and let it decel by itself. After doing this the rings should be sealed. Do a compression and leak down test if everything is good drive it however you want as long as its tuned to be that way. Thats what i always did never had one problem
this is how you break in a v8 domestic with a carb. this doesn't apply to newer EFI motors anymore...
Old Dec 22, 2005 | 10:23 AM
04 rs's Avatar
UMMMM, ive broken in plenty of fuel injected motors like that. Why would it matter if the motor was carborated???? it wouldnt, so whats the difference since you seam to know.
Old Dec 22, 2005 | 12:32 PM
C6C6CH3vo's Avatar
Change the oil every 500 miles and drive it hard but keep rpms under 7500
Old Dec 22, 2005 | 12:47 PM
Cannonballer's Avatar
Flog it.
Old Dec 22, 2005 | 12:59 PM
P_A_STREET_EVO8's Avatar
Just go on a road trip for 500 miles that what i did had 500 miles the second day of haveing the car , as soon as i hit 500 i droped a gear and red lined it on 4th and took it up to 150 on 5th. 50k later car still running like new only thing that has gone out was the clutch and t/c at 40k.
Old Dec 22, 2005 | 01:06 PM
yesevo's Avatar
so u dont believe in what it says on this website?
Old Dec 22, 2005 | 01:09 PM
Cloud's Avatar
I believe what this website says, and it's how I broke in my brand new Evo.
And if you actually read the article is says it applies to all 4 stroke engines, not just
A carb V8.
Old Dec 22, 2005 | 02:17 PM
Rastmp's Avatar
I can tell you that i broke in my new evo HARD....first 200 miles....Changed the oil 3x first 1000 miles....
I can tell you that my evo is very high HP stock..It dynoed at 277WHP...I am not saying that the break in is responsible...but it helped.
Old Dec 22, 2005 | 02:25 PM
Alias's Avatar
tell me about it~
When you search, did you use BREAK or BRAKE???
Old Dec 22, 2005 | 02:41 PM
kcevo's Avatar
FYI, this might be of interest to you. This is from Eric at AMS.
Tom, Here is how we break in motors here with regards to oil:
For the first 500 miles drive at varrying engine speeds. dont baby it but dont shoot the moon with it. The key is seating the rings in a variety of partial throttle and short bursts of acceleration. After accelerating let off the throttle, while still in gear, letting the engine slow down the car.
Check the oil at every fill up. The shop staff here does that with there own cars every time they fill up if that means anything.
Please keep in mind the new motor will consume a little bit of oil durring break in and even after. Heavy abuse and high boost levels will consume oil on even a healthy motor.
here is how the oil change should break down.
First oil change at 20 miles 10W40 dinosaur oil...we use penzoil
Second oil change at 500 miles 10W40 dinosaur oil
Third Oil change at 1500 miles 10W40 dinosaur Oil
From here on out you can change the oil at 3000 mile intervals and may switch to synthetic if you choose.
You can never check you oil too much
Eric
