Oil leak easy question
Old Dec 27, 2005 | 03:57 PM
GTVEVO's Avatar
Originally Posted by jesterEVO
maybe caused by track shifting?
If the car is under warenty get it fixed, other wise for him to sit and look at it wouldn't be an example of how much it would leak if you were under boost becuase things get pressurized. I would start keeping track of the oil loss daily until you figure out just how bad it is in light and hard driving. If it isn't bad I wouldn't worry but if it is I would get it replaced.
Old Dec 27, 2005 | 03:59 PM
justchil's Avatar
I'm not sure.. I was assuming old age but you have a 2005 hmm
Maybe this could be another excuse for motor mounts.. Either way ^^ just like above.. keep an eye on your fluid levels and get it fixed before it does become a problem.
Old Dec 27, 2005 | 05:32 PM
dubbleugly01's Avatar
the verdict with the dye leak test was that the oil filler was loose causing a majority of the leak and also a crank shaft seal leak...he said it wasnt major nothing to worry about ....he said 90% of the problem was the oil filler or might of been 99%...but gave the warning that the crank shaft seal could cause a proglem in the future...then went on to say you he had to sit there a stare at it forever under the black light to even see the leak in the crank shaft..what you guys think about that?
the rear main seal should be covered up by the flywheel. How did they stare at it for a couple minutes???? I don't see how they could even see it. Especially for $41. What am I missing?
Old Dec 27, 2005 | 08:53 PM
05SilverEvoVIII's Avatar
Originally Posted by burtomr
"....and oil based leaky look..."
didnt know how to phrase that
Old Dec 28, 2005 | 01:50 PM
jesterEVO's Avatar
here is the mechanics description i just called....the bottom pulley if you take the bolt out removing the timing cover there is a seal behind the bolt. Thats leaking a very small bit not bad at all... i dont know if i got that backwards but those are the words he used...he said i could come by tomorrow he would put it on a lift and show me
Old Dec 28, 2005 | 01:54 PM
jesterEVO's Avatar
is that and easy thing to fix? what could of caused that?
Old Dec 28, 2005 | 01:56 PM
jesterEVO's Avatar
i didnt know crank shafts had pulleys...weird
Old Dec 28, 2005 | 02:14 PM
KINGEVO7's Avatar
the end :]
Old Dec 28, 2005 | 02:24 PM
jesterEVO's Avatar
deleted
Old Dec 29, 2005 | 07:35 PM
jesterEVO's Avatar
delete
