Noises
Old Dec 29, 2005 | 07:27 AM
rkm625's Avatar
Noises
Most of the time when I let off the gas there is a grinding type of noise. It seems like its been doing this for a while so I cant really figure it out. I dont think its the exhaust, it sounds more like the drivetrain or clutch chatter
any ideas?
Old Dec 29, 2005 | 07:32 AM
MuslimEvoFreak's Avatar
If you have warranty, and no mods, then take it to the dealer. Good luck though man!
Old Dec 29, 2005 | 07:43 AM
Ranskaa's Avatar
does it only happen when you let off the gas?
does it matter if the clutch is in or out?
Old Dec 29, 2005 | 07:51 AM
rkm625's Avatar
only when the clutch is in and I let off the gas.
and i'm out of warranty with mods
The car runs fine as far as I can tell, it just makes noises
Old Dec 29, 2005 | 07:21 PM
rkm625's Avatar
ttt
Old Dec 29, 2005 | 07:32 PM
EVOlutionary's Avatar
It is most likely gear whine of the transmission or the transfer case. As I have put more hard miles on my car it has gotten much louder. Also, if you have an aftermarket clutch it could be clutch noise as the aftermarket units don't have the quieting features of the stock unit (remember there are springs in the clutch disc and it can move back and forth a bit)
Just my thoughts.
EVOlutionary
Old Dec 29, 2005 | 07:39 PM
Fa$[- a$ $hi[-'s Avatar
if it does it in 1st gear with the car in gear and you let off the gas and the clutch is either engaged or disengaged, and sounds like there is gravel spinning around in a bucket, then that is normal. mine has done that since i got mine new and i've had no problems.
Old Dec 29, 2005 | 08:04 PM
rkm625's Avatar
I'm thinkin its either gear whine, the ACT clutch or the loud *** Apex'i GT exhaust...
Old Dec 30, 2005 | 07:16 PM
rkm625's Avatar
ttt
Old Dec 30, 2005 | 07:50 PM
ACTman's Avatar
If the clutch is in, the ACT should not be making any noise since no power or torsional vibrations are being transmitted from the engine to the trans.
Old Dec 31, 2005 | 04:46 AM
rkm625's Avatar
the clutch is out and the car is in gear. example: I'm accelerating and then i just let off the gas.
Old Dec 31, 2005 | 12:08 PM
ACTman's Avatar
OK then it may be just decel gear noise which may be louder than with the stock clutch especially if you changed to a lighter flywheel too. Earlier you stated with the "clutch in" so I was confused.
Old Dec 31, 2005 | 03:02 PM
rkm625's Avatar
yeah its the ACT street disk with lightened flywheel. Thats probably all it is. Thanks for the response!
I'm still scared to really drive it hard. I probably have around 290-300 WHP. Any tips on how not to kill the clutch other than the obvious (slipping and high RPM launches) ??
Old Dec 31, 2005 | 05:04 PM
ACTman's Avatar
With that power level you can drive it about as hard as you like as long as you don't slip the clutch and the restrictor is removed. Dropping the clutch or high rpm won't be a problem at all. That is just harder on other parts.
Old Dec 31, 2005 | 07:50 PM
rkm625's Avatar
if the restrictor isn't removed that just means it will slip the clutch instead of just dropping it all on the clutch so that it saves those "other parts"
