Who can size these turbos in the correct order??
Originally Posted by DynoFlash
here are the turbos I consider relevant
2005 Ev0 16g
evo IX stock
IX 20G by Buschur
Gt35R
Gt42R
Given the way the GT35 and IX turbos work - I would not personally consider any Gt30 based unit of a 50 trim
2005 Ev0 16g
evo IX stock
IX 20G by Buschur
Gt35R
Gt42R
Originally Posted by fromWRXtoEVO
I am familiar to Mitusbishi turbos sizes since I had upgraded multiple of my cars in the past to upgraded mitsubishi turbos
I think your information about the 16G and the 20G is a bit off, as I mention before the Big 16g flows about 550CFM and a 20G flows 650CFM @15PSI, this means that the difference in flow is 15.6%.
The reference that you use about 40lbm and 43 lbm would give you a 6.98% increase. I know Mitsubishi turbos fairly well, I have had my car turbos in the past upgraded to:
91 GSx with a Evo III turbo
90 Laser to a Big 16G
91 Stealth TT from 9bs to 13G turbos
03 WRX to 18G reverse thrust impelers
These are a few links to address my point:
http://www.turboclub.com/makes/mit/S...CNMTURBOS.html
http://forums.nasioc.com/forums/arch.../t-278517.html
http://forums.clubrsx.com/archive/in.../t-256688.html
my .2c
my .2c
small 16g flows 505cfm or 34lb/min
big 16g flows 575cfm or about 38lb/min
18g flows 600cfm or about 40lb/min
evo 3 16g flows 625cfm or about 42lb/min
evo 8 16g flows 625cfm or 42lb/min
20g flows 650cfm or 43.7 lb/minute.
there are three different 16g wheels coming from the dsm line of turbos. the evo8 is reverse rotation and is a mirror image of the evo 3 16g dsm turbo. but who on this board really cares about the dsm turbos anyway. only the 20g wheel is worth knowing about since it is the only one that flows more than the evo16.
holy .....you guys are killing me. The shop is ready to order me the turbo and i told him to wait another day. I already paid for it. I think both you guys are truly knowledgable......But it doesnt help me get it right the first time!!! Thanks for the input......i dont want a monster turbo. Just total effeciency at 425-450 HP. If i get a GT, ime outa cash for the injectors and wastegate. Freaking FULL-RACE stuff is expensive......but NICE!!!!! So 50 or 57.....or get another POS 35r.........
Originally Posted by Ted B
Not a good choice for an EVO. That 60-1 is intended to run low boost pressure on a higher compression V8. It's peak efficiency range is around 12psi, which makes it a poor choice for our application
Originally Posted by Drifto
Not true.
http://www.pagparts.com/Garrett_Turb...ype=t460-1trim
Your argument is like saying that because someone made good power with a 2.5" exhaust on an EVO that it's equal to a 3", and that isn't the case.
Does it mean that the turbo cannot deliver good power? No.
Does it mean that a better suited turbo will give better power potential at the same settings? Absolutely.
One can only know what he has and cannot know what he's missing . . . unless of course he makes a swap and sees the difference.
2005 Ev0 16g
evo IX stock
IX 20G by Buschur
Gt35R
Gt42R
2005 Ev0 16g
evo IX stock
IX 20G by Buschur
Gt35R
Gt42R
Originally Posted by BadazzCR
x2... eighter keep it stock or go big, all the middle turbos are a waste of time IMHO.
2005 Ev0 16g
evo IX stock
IX 20G by Buschur
Gt35R
Gt42R
2005 Ev0 16g
evo IX stock
IX 20G by Buschur
Gt35R
Gt42R
What is wrong with using the GT30R namely the 3076R and the 3071R? People are making good spool and the 76R makes 500WHP on pump and alky?
stock 2.0l block - Evo IX turbo, 3071 are good upgrades, especially for street use/road racing. The 3076 is somewhat laggy and 35r and larger are really laggy.
built 2.0l block - 3071 is almost too small, runs out of steam up top (i.e. past 8000 rpms). The 35r and 42r can really shine for drag racing on this platform - as demonstrated by AMS and others.
2.3/2.4 stroker - street/road racing: 3071 will spool really early, very potent as RRE has demonstrated. A 3076 and 35r are also very potent. Hell, anything short of the stock turbo is potent on a stroker.
l8r)
Originally Posted by Ludikraut
IMO it all depends on the intended use of the car:
l8r)
l8r)
Sean IV is running past 8500 on a stock Head stock bottom end Evo VIII with a 35R.
I still have my heart set on a GT3076R and getting a nice power band from 4000-8000+
Sean IV is running past 8500 on a stock Head stock bottom end Evo VIII with a 35R...
.. I still have my heart set on a GT3076R and getting a nice power band from 4000-8000+
l8r)
