Who can size these turbos in the correct order??
Originally Posted by Jaylenospoolboy
How do you get to 600 WHP when Garrett states the 30R's will only make up to 500 crank hp? Am I missing something?
Originally Posted by WrX Kila
I believe Garret turbo's are underated.
Originally Posted by Full-Race Geoff
i would recommend trying out a .82 a/r housing... you may find that the lag does not increase at all, yet top end increases significantly, particularly if using a properly designed long runner merge collector manifold and a properly designed downpipe
l8r)
how would the 3076 be without cams? im debating if i should just install my turbo now and maybe get cams in the future or if i should just get 272 and install both at once. i'm tired of having my turbo sit around. i want to put it in already but i have no money for cams at this time
Get 272's. Do it right.
GT3071 still around
Originally Posted by Ludikraut
I'm leery of stepping up to a 3076, because the spoolup of my 3071, while acceptable, is already a little bit laggier than I thought it would be. So now that Garrett has downsized the 3071, it seems that there is a gap, so-to-speak in their turbo lineup.
l8r)
l8r)
The third version is the traditional GT3071R which comes from Garrett as a CHRA (their distributors bolt on factory Garrett housings to make it a complete turbo). This version has the same 60mm turbine wheel as the GT3076R, and therefore can use the same range of T3-inlet turbine housings.
So there is no real gap, it's just that Garrett doesn't list this latter GT3071R on their site since the site only lists complete turbos (with few key exceptions like GT42/R). They sell tons of CHRAs and components that aren't listed on their website. If they listed ALL their bits the site would be immense.
FWIW
And wouldn't you rather a turbo support higher hp than its rating indicates, instead of the other way around?
evo3matt
159
Feb 8, 2006 06:37 AM
RnR Racing
Aug 1, 2005 01:53 PM
