powerflex or buschur motor mount/bushing?
Old Apr 17, 2006 | 12:22 PM
  #76
SuperHatch's Avatar
Mark,
Here's the thread, I did the legwork for ya...
https://www.evolutionm.net/forums/sh...alliart+mounts
Thanks kekek for the pics.
- Steve
Old Apr 17, 2006 | 12:43 PM
  #77
trinydex's Avatar
"woot woot"
Old Apr 18, 2006 | 07:53 AM
  #78
marksae's Avatar
Originally Posted by SuperHatch
Mark,
- Steve
Cool. Thanks for the link Steve.
Are all 4 mounts the same diameter in size? Do you remember what size die or socket you used to press the stock mounts out?
How hard is it to get to the rear mount if I don't plan on taking my tranny out? If it's anything like a 2g DSM, the rear is probably the hardest one.
Old Apr 18, 2006 | 08:20 AM
  #79
SuperHatch's Avatar
The rear mount is smaller in diameter than the other three. I didn't do the pressing, a friend of mine that goes to UTI did it for me, so I don't know what size dies he used, sorry...
The rear mount isn't tough to get to if you pull the upper intercooler pipe and the battery. You sill still need to get creative with your wrench selection, but it isn't impossible.
The tranny side mount is the real challenge. You need to lower the tranny a good 2"-3" to be able to lift the mount off the studs on the tranny housing. This could put some serious stain on the flexibility of the CV shafts/exhaust/driveshaft, I'm not sure though to be honest with you. My tranny and TC were out of the car when I was doing the install, and my motor was hanging by a strut tower mounted support brace so every single mount was removed at the same time.
- Steve
Old Apr 18, 2006 | 09:49 AM
  #80
kekek's Avatar
The mounts aren't all the same diameter. If you don't have access to a machine shop to make dies I would recommend the following:
1) Place the Ralliart mounts in a freezer for a day or so to "shrink" them.
2) Remove the stock mounts. Drill holes in the stock rubber mount. Enough to get a hacksaw in. Cut through the sleeve and hammer it out.
3) Get a large steel piece, I used an L-bracket from the Depot, to span the mount. Apply a small amount of grease to the leading edge of the bushing being pressed in. Make sure you are pressing the outer sleeve and not the steel inner bushing.
4) Press that sucker in. Pay attention, go slow and make sure it starts straight. I bought a 12-ton $80 deal from Harbor Freight, it worked well for everything (motor/tranny mounts, all suspension and rear diff (Thanks Mark!)).
Just like Superhatch said about the rear mount, I totally agree. I also agree with his statement about the tranny side mount. I too had everything out at TRE so access for me was plentiful.
Old Apr 18, 2006 | 09:54 AM
  #81
SuperHatch's Avatar
There you go mark... all the info you needed from two reputable sources.
Old Apr 18, 2006 | 09:59 AM
  #82
voidhawk's Avatar
If you do not want to destroy your stock mount, you can press them out using PVC pipe and a mallet. I've only done this with the front, but you can get a $3 PVC pipe female/female coupler (or size reducer) at the Home Depot that has the exact same diameter as the front mount bracket on one side, and a larger diameter on the other. Then get the matching PVC pipe (they sell small lengths for about a buck as well). Place the female adapter on the floor, put the mount on it, and use the male pipe piece and a mallet to pound out the mount. If it gets stuck in the PVC adapter, crack it open with a hack saw afterwards. Works like a charm. The PVC adapter is white, the pipe is a black piece - should be easy to find.
Old Apr 18, 2006 | 10:08 AM
  #83
marksae's Avatar
Cool. Thanks for all the info guys!
Old Apr 19, 2006 | 07:42 PM
  #84
Smogrunner's Avatar
Where can I buy the Ralliart Mounts. I want to order them tomorrow, first thing. Gruppe S sells them but it looks like they are out of stock. Anyone?
Old Apr 19, 2006 | 08:02 PM
  #85
kekek's Avatar
Try Adam at Z1. I think he had these on special recently.
Old Apr 19, 2006 | 08:11 PM
  #86
TTP Engineering's Avatar
We have about 4 sets of the U.K. POWERFLEX units in stock ready to ship.
PM me for special pricing for the last few sets in inventory!
Old Apr 20, 2006 | 04:19 AM
  #87
SuperHatch's Avatar
He did have them on special... $175 shipped, but I think I got his last set....
This was a few weeks ago though, so he might have gotten more in.
Old Apr 21, 2006 | 07:01 AM
  #88
Smogrunner's Avatar
Yes, they are out of the Ralliart mounts. I called yesterday.
Old Jun 17, 2006 | 06:09 PM
  #89
o.e.boost's Avatar
i bought the mounts a while ago but havent had time to install them...but i was looking at the front mount and the sleeve is a bit wobbly???...david is it suppost to be like that...the back mount is okay as the sleeve doesn't even move...help me out here?
TommiM
15
Sep 30, 2014 04:46 PM
TTP Engineering
150
Oct 3, 2006 09:30 AM
Mike@Forge
43
Mar 15, 2006 08:07 AM
joeymia
35
Jan 1, 2006 08:23 PM
nothere
Northwest Region
Dec 15, 2005 02:55 PM
