Engine Build Advice
I recently fried my pistons and rods and I 'm now trying to rebuild my engine. However im not sure what to build my engine with in terms of pistons or rods. And if i should get valves and retainers while im at it.
This car is my daily driver and I'm on the stock turbo and probably wont be able to get a bigger turbo for a while but if anything ill go with a 20g.
Any suggestions or advice?
Thanks,
Chris
Thanks,
Chris
if you can afford it, just buy a Cosworth head, slap in some Omega pistons, Eagle or HKS rods, ARP head bolts, Cometic head gasket. & while you're at it, slap on some Tomei 280 cams (11.8 lift), HKS cam gears, & Tomei kevlar timing belt. the Cosworth head will already have new valve guides, & retainers. your head will then pull to 9k rpm all day long after a tune of course...
If I was building a daily driver from the ground up, from my existing block I would simply do a 2.3 stroker kit. You'll probably have to have the bores honed anyway with the rebuild and why not go for a bit more displacement. You can get good power gains on a relatively stock car on the stock turbo.
BIG MONEY....
l8r)
If its going to be daily driven and you want it to last a while I would go with wiseco pistons which can run nice tight clearence's and some crower rods. Depending on how extreme you want the car to be you could always get a galant crank and make it a 2.3 or go a full 2.4 4g64 block.
Originally Posted by BlueFastEvoVIII
anybody know how a stroker is daily driven
They are delicious. Once you drive one you won't want to go back to a 2.0. But the cost is a lot higher.
It'll cost $6-7 K just to get a 2.3/2.4 in there, if you want a turbo kit to fit it around $10K. Plan on down time 2-3 weeks longer with any built motor. It just seems to work out that way.
You can buy a brand new 2.0 dealer shortblock delivered for about $2k with a core and get your block r and r'd for about $1000 - $1500. I've posted where a few times so thread search if interested.
Another thing about the strokers is the little turbos get amazing torque but run out of steam up top, but as a daily driver you don't use the top and they're way fun in traffic - you can jump v8's with them on pump gas.
