is this clutch slippage or what???
Old Jan 17, 2006 | 03:10 PM
totalsbl14's Avatar
Question is this clutch slippage or what???
I have a evo VIII 03 with 24,000 miles and Ive been having this problem latly. When i hit the gas my car goes to about 4 grand and then drops to about 3800, lags for a little and then takes off. i dont think i have a boost leak i watch the boost gauge and it seems right. My friend said it was the cluth but i dont think thats right cuz it doenst slip and i can launch it still pretty good. I changed the plugs and put a walbro fuel pump in. Another friend said it was my coil pack or something with ignition. Any answers im stunned on what it is?????????
Old Jan 17, 2006 | 03:37 PM
nlped's Avatar
If it is falling off of RPM it sounds like how my car did right when my clutch began its death march. That isn't much of an RPM drop though...it could be something else, but I would probably hope for a clutch issue vs. having to deal with the dealer over electronic issues. Good Luck.
Old Jan 17, 2006 | 03:38 PM
DaWorstPlaya's Avatar
Sounds like you clutch is starting to slip ... time for an ACT ...
Old Jan 17, 2006 | 03:44 PM
Curt@MrLed's Avatar
Former Vendor
clutch time.
Old Jan 17, 2006 | 03:51 PM
slo4g63's Avatar
So...if it is going to 4k without slipping, I wouldn't think it's a clutch? If it is dropping back to 3800, that could be something else. That's a wierd sympton though, it sounds like a clutch slip upto 4k and that's why it falls back once it catches. But I would think it would slip around 4k under boost. good luck and let us know what you find. I'm still a newbie, but damn, it doesn't sound like clutch slip, unless your wrong.
Question, your launch? Being pretty good, do you mean launching under boost or are you referring to just quick takeoffs from the occasional traffic light? theres a big difference, just trying to find out what you mean.
Old Jan 17, 2006 | 04:13 PM
totalsbl14's Avatar
yea but i still get speed not like my rpms shoot up and i dont go anywhere
Old Jan 17, 2006 | 05:01 PM
fsugatorbait's Avatar
1500 rpms in 5th gear and punch it.
Old Jan 17, 2006 | 05:05 PM
silver_evo's Avatar
I had that happen in my old B16a crx, it started in 5th the rpms would go up and speed wouldnt (haha no funny honda jokes) then it started in 4th, by the end of the week i barely got any power down, i had the clutch cable adjusted (it was a Stg3 Clutch Master Kevlar). Not sure if it was breaking in, or having an early death, but since our clutches are hydraulic, id say is clutch slippage. Maybe check if oil is getting on the clutch from possible bad gasket, i doubt it, 24k miles is early for that, either you beat it up good or its slipping for other reasons.
Old Jan 17, 2006 | 05:25 PM
Ckjeepin's Avatar
yup mine did that very slightly a couple weeks ago and now its barely driveable.. Go easy on it.
Old Jan 17, 2006 | 08:56 PM
totalsbl14's Avatar
so then wha is it if it happened to you did u ge it fixed
Old Jan 17, 2006 | 08:58 PM
totalsbl14's Avatar
slo4g63 i mean launch under boost i still spin all 4
Old Jan 18, 2006 | 08:13 AM
slo4g63's Avatar
Well, I don't have anymore knowledge to share, maybe one of the tuners or someone that has had this experience can share the info...
Old Jan 18, 2006 | 08:25 AM
4rcd6's Avatar
ya know my 2 cents! CLUTCH!
Thats how it begins with a slowly diminishing clutch plate. It just slips a tad(few hundred rpm) usually at high gears. It gets worse over time especially if you drive hard.
Mine just bit the dust after a few good runs with some buddies in the car.
Old Jan 18, 2006 | 09:02 AM
Yeah that!
If your not going to listen to advice when its given then why ask in the 1st place?
Old Jan 18, 2006 | 09:10 AM
4rcd6's Avatar
the thing is, if he doesnt realize its the clutch now... he soon enough will after wasting time trying to find another problem.
Its called DENIAL which lots of ppl have. Its a known problem to have weak a$$ clutches in the evo. Everyone who has had one for awhile knows this since they've all gone through it. Order a ACT HD and prepare to get it done. You could get stranded while your unprepared.
Take our advise please.... there has been so many threads with the clutch issue its insane
