anyone with 05 evo that has gear grinding
Old Jan 18, 2006 | 02:28 PM
mb32's Avatar
anyone who has problems with shifting at high rpm and the gear grind. if so post comments and describe the problem. i know im not the only one.
Old Jan 18, 2006 | 02:38 PM
navysevo's Avatar
not here
Old Jan 18, 2006 | 02:53 PM
alloyic_rs's Avatar
did you do some hard core high rpm gear shifting? or did it start grinding for no reason
Old Jan 18, 2006 | 02:58 PM
MuslimEvoFreak's Avatar
I have grinding issues, read my post man!
Old Jan 18, 2006 | 02:59 PM
mb32's Avatar
just at about 5 to 6 rpm i shift fast and it does it. the dealer talk to the mitsubishi tech line and they said that i was the only case they have ever heard anywhere.
Old Jan 18, 2006 | 03:00 PM
mb32's Avatar
navysevo you dont have stock clutch though.
Old Jan 18, 2006 | 03:05 PM
ROGERV's Avatar
no problems here.
Old Jan 18, 2006 | 03:08 PM
4WS Tuning's Avatar
06 and it grinds into 5th if i shirt above 5500 from 4th...if i double clutch it doesn't do it or if i shift slow/normal....i think if i get better fluids it might stop...any ideas?
Old Jan 18, 2006 | 03:09 PM
evo637's Avatar
I think its just your timing.
mb32's Avatar
did you by it off the lot brand new?
Old Jan 18, 2006 | 03:12 PM
Turbo Meg's Avatar
I had mild gear grinding when shifting at high rpm from 1st to 2nd. I solved the problem completely with BG Synchro Shift trans fluid. I got it at the Lancer Shop. http://www.lancershop.com/customer/p...0&cat=6&page=1
Old Jan 18, 2006 | 04:23 PM
shivaswrath's Avatar
are doing this on a cold tranny or have you warmed up and lubed your gears by rowing through them?? this is crucial? Might be technique, sometimes I feel a little notchy-catchyness on a 2-3 shift on my 05, but that's because I wasn't shifting into the gate well. .
Old Jan 18, 2006 | 08:03 PM
ACTman's Avatar
Adjust the rod at the pedal assembly for higher release point. If it helps, inadequate release is the problem. If it nets no improvement, then it is something else. Adjustment is definitely the first thing I would try.
Old Jan 19, 2006 | 05:31 AM
sharmin7's Avatar
every once and awhile i have some grinding at higher rpms, you really have to throw the shifter hard to get it into gear as well. ive talked to a few people and they said i should purchase the shifter bushings which make a world of difference. i havent gotten any logical answers on why this is happening though.
Old Jan 19, 2006 | 06:15 AM
Doogie Howser's Avatar
No trying to force anything while shifting is never good and will eventually lead to serious problems down the road.
Try the clutch adjustment as Actman suggested and if your still getting grinds then its dealer or TRE/SHEP time.
