Shift lockout (sitting still) Trans?
Old Jan 20, 2006 | 02:38 PM
MDoe8's Avatar
exedy basic upgrade clutch, no other drivetrain modifications
Old Jan 20, 2006 | 04:35 PM
Dropspeed's Avatar
This happens when the car is sitting still and the motor is not running................I can get it to act just by shifting 1-2 2-1 1-2 Lock.......lock lock lock lock-1 ECt.
That is what really has me confused. I am going to chek the linkage and then pull the trans tonight......
Matt
Old Jan 20, 2006 | 04:45 PM
dadriva's Avatar
Do you have aftermarket under hood shifter bushings?
I have had the same prob. All it took was some lube on the larger underhood bushing.
(I forgot to lube mine when I installed it)
Old Jan 20, 2006 | 08:43 PM
ACTman's Avatar
Matt
Hey Matt, I hope all is well!
Usually you can ignore how the car shifts when the engine if off. The trans acts differently when the engine is not running. In that case the syncros have no function at all. Since the parts are not spinning there is nothing to "sync" to the same speed. It is quite common to not be able to get into gear when the engine is off, clutch or not.
Old Jan 20, 2006 | 11:14 PM
Dropspeed's Avatar
Hey Dirk,
Maybe I have never tried it before like that (not running). But after it acted up when driving I started to pay attention to it even more. After inspecting the linkage. I drained the fluid.........................MMMM lets just say there was a little to much in the way of metal attached to the drain plug for my liking. (It might have been a complete syncro)...............
4 hours later the trans in is the back of my truck. Tomorrow its off to Kalamazoo to drop off with Jon @ TRE. (I was heading to that side of the state anyway.)
Matt
TomekEVO
Oct 18, 2015 07:48 PM
raywong
40
Sep 16, 2015 03:49 PM
JorgeAvila
Oct 9, 2014 04:05 PM
Kreeker
14
Mar 25, 2014 04:35 PM
