problems in the ix..
Old Jan 20, 2006 | 06:38 PM
jrsimon27's Avatar
remeber evo 8 and evo 9 have a imo a totally differen head.
Old Jan 20, 2006 | 06:39 PM
jrsimon27's Avatar
Originally Posted by diiirk
there is a slight possibility that a piece of porcelin fell into the cylinder when i first took out the broken plug, i highly doubt it, but this would explain the noise we heard when it started up. could have been the piece moving in the cylinder and it stopped becuase it was released through an exhaust valve
very possible.
GgreyEVOIX's Avatar
IF it aint broke don't fix it.......
Old Jan 20, 2006 | 06:40 PM
diiirk@AwdMotorsports's Avatar
but it is broke right now, and im asking for help, and i havent had a helpful reply yet.
jrsimon27's Avatar
just check your tools the car to have tools when new, and use the evo 9 tool maybe this helps
Old Jan 20, 2006 | 06:42 PM
RedEvoInKy's Avatar
Did you put the plug wires on the plugs in the right order? In other words, maybe you have wire 1 on plug 2, and so on.
jrsimon27's Avatar
do you have your original tools?
Old Jan 20, 2006 | 06:44 PM
jrsimon27's Avatar
well but think about it why would the plugs be broked before when they were never out of the car?? this is really strange.
Old Jan 20, 2006 | 06:46 PM
yes i was suggesting that they broke in the engin or they broke when they were removed(by the tool)
Old Jan 20, 2006 | 06:47 PM
the plug wires were put on correctly
Old Jan 20, 2006 | 06:52 PM
jrsimon27's Avatar
use your original tool maybe this helps
Old Jan 20, 2006 | 06:53 PM
C6C6CH3vo's Avatar
Do not gap the exact replacement irridiums. You can use a feeler guage to see if their in tolerance.
Torque plugs 18 foot/lbs (I think).
After plugs are in and torqued, if she's still missing, make sure ignition is in "OFF" (just remove key) then disconnect negative terminal to the battery for no less than 15 minutes.
If still bad, carefully inspect everywhere that you have worked on the car, connections, hoses, lines, connectors, etc.
If you still can't get it right, you will need to post a more specific list of events from when you first noticed the problem (and what you recently did prior) to current.
Hint, just write important facts, not one long paragraph
Old Jan 20, 2006 | 07:01 PM
everything is listed..
-pulled stock plugs to do compression test, porcelin was broke. maybe from engine maybe from tool
-car sat with no plugs overnight until i could get new plugs
-new plugs were installed
-started the car and there was a clicking noise like maybe a piece of porcelin moving around in the cylinder, the noise stopped and the car was misfiring and idle would not settle(wanted to stall)
-idle settled and warmed up to operating temp
-revved engine a little and at 5k the misfiring conitnued until it stalled
-pulled plugs and they were broke once again, maybe from tool.
the car was running great, except for a little dip in idle from time to time up until the new plugs went in today
Old Jan 20, 2006 | 07:10 PM
jrsimon27's Avatar
90% the tool is your problem
Old Jan 20, 2006 | 07:14 PM
ok so tomorow im putting the plugs in myself so i can be extra careful, checking all my vac lines and connections and u say use the tools from the car, i didnt kno the car came with a socket for removing the plugs. also it was recommended that i disconnect the battery for 10 seconds if it still misfires, but will this erase my dynoflash??
