Dyno results - Pruven Perf. Test pipe - SAFC and Boost contr - 275 wheel hp
I just got my car dynoed at www.pruvenperformance.com - - so far I added the following :
Pruven Perf. test pipe
S-AFC
HKS EVC V
I am over 40 wheel hp over stock and did not loose ANY spool up or drivability feel
Car runs great ! Thanks Pruven
(Note - this is on 94 octane)
S-AFC
HKS EVC V
Originally posted by Alfriedesq
it dips down a bit richer to the end - - the stock car is very lean in the mid and rich at the top - - the super afc works it perefct
Do you feel any jerkyness with the S-AFC??
Do you feel this 5spd is strong??
Any knock??
Can you bost your dyno sheet?
Thanks
Eric L.
Nice.. lets see a dyno sheet of before and after!
I want to put an AFC on my car, but don't like the idea of splicing wires on the stock harness. But for as cheap as they are and the gains possible.. hmmm..
-Zach
-Zach
Impressive . I'm getting a baseline for my evo on a dynapack next week and hopfully i'll get mine 1/4 MI tested. Then i'll redyno it when i decieded to mod it and then track test it to confirm my gains .
What dyno are you running AL? 40 WHP is very impressive at 20psi's.
Originally posted by Eric Lyublinsky
Hey Al, Looking good. EVOs are really nice. Still waiting on making a chose EVO or STI at this point or just keep pluging away on my WRX but the Evo looks very nice.
Any knock??
Thanks
Eric L.
Any knock??
Thanks
Eric L.
No jerkyness with the super AFC - its smooth - but the dyno does show a dip in both the stock can and my car between 5200 - 5800 rpm and it looks to me like a timing issue - whether its becuase I saw some detonation there and it self adjusted - or if its just the way the stock curve is - I dont know - - I though I read somehing from vishnu that they had a timing curve issue at that rpm point also
No knock I can hear-but I need a knock link
Here is a video and some pictures - you can hear how nice they have it running in the video - - -
http://www.pruvenperformance.com/alevo.htm
It's my think, power or torque drop 5200~5800rpm.
happen ECU'S OVER BOOST CUT FUNCTION not igniton
timing issue.
in the case EVO7, 5200~5500 rpm's max boost is 1.3bar
(18.7psi)
if you have change down pipe or Exhaust.
It makes easy to reach target boost.
but that makes easy to reach overboost too.
after the EVO7, stock ECU controlled Overboost.
in the case on EVO7
3000~6000rpm : 1.3bar(18.5psi)
at 6000rpm : 1.2bar(17psi)
6000~ : 1.1bar(15psi)
May be you can solve this symtom.
use stock pipe or use little small pipe.
but best way is reprogram ECU or BOOST CUT DEFENSER with
Piggy back like HKS F con-S, F con-V Pro, Greddy E-manage...
(Please do not use defenser alone)
Sorry for my poor english, I'm Korean.
So, english expression makes me crazy
timing issue.
(18.7psi)
in the case on EVO7
Re: Dyno results - Pruven Perf. Test pipe - SAFC and Boost contr - 275 wheel hp
S-AFC
HKS EVC V
S-AFC
HKS EVC V
