Torque Monster Evo 9 MR!! Dyno plots!!
Old Jan 27, 2006 | 12:25 PM
  #31
Warrtalon's Avatar
Originally Posted by TURBODAWG
Stock plugs are fine in this car. We DO have an HKS DLI2 ignition on this car. I think that is the reason you are having trouble with yours blowing out the spark. You need to get the HKS DLI2.
I kinda deserve a "duh" on that one. I overlooked that fact, even though I specifically remember reading it. You're right in that I could very well be needing an HKS DLI2 with the boost I'm running, especially once I have the cams. My BR8ES are holding up, but we were seeing some break up on the dyno at higher boost. I have to admit I didn't know that a DLI2 like that would allow for running more efficiently even with stock range plugs. Is that the case? I have no experience with any aftermarket ignition, so this is good info to me.
Old Jan 27, 2006 | 12:36 PM
  #32
TURBODAWG's Avatar
I have found that the stock plugs work extemely well even at high boost pressures when coupled with the HKS DLI2.... We have also had good experience with the BR8EIX iridum plugs. They are similiar in design to the stock plugs but are only about $7 or $8 at Advance autoparts. I dont believe in downgrading to copper plugs over and Iridium. Thats just my stupid opinion on that, I guess.
Brian
Old Jan 27, 2006 | 12:46 PM
  #33
scorke's Avatar
A lot of power, but a ton of boost......
Scorke
Old Jan 27, 2006 | 01:28 PM
  #34
DaWorstPlaya's Avatar
Scorke
My thoughts exactly ... I guess the redesigned cooling passages and pistons go a long way to combat knock .... add mivec and 20G-9 ...
Old Jan 27, 2006 | 01:37 PM
  #35
Bom's Evo's Avatar
wow! that must be a blast to drive with the 6spd!
Old Jan 27, 2006 | 02:22 PM
  #36
althemean's Avatar
They are running a stock intake cam with an HKS 264 exhaust?? How does MIVEC handle that combo??
And the Evo8WR converted to 9 parts....I take it then that its a TME internals with 9 compressor housing?? but not a BR 9 20G.....??
so confused.....
Old Jan 27, 2006 | 02:41 PM
  #37
blowoffsilver's Avatar
so confused.....
no its not a 20g-9 its a white rabbit 9 and yes tme internals and 9 housing
man matts car is a beast, i couldnt believe it would put down so good of tor numbers, so i would love to see it on topspeeds dyno tommoro if doug will let us. it was a thrill to see this thing raised up the front end while on the dyno, it was like in .2 tenths of a second it just wanted to leap off, the turbo spolls very fast on this thing. i am very impressed with these 9's.
Old Jan 27, 2006 | 02:52 PM
  #38
Maximum Boost's Avatar
I can't wait to see it at the drag strip!
Old Jan 27, 2006 | 03:39 PM
  #39
BoostMonster's Avatar
Nice job. Is this going to be the Johnson's racing stage 1.
Old Jan 27, 2006 | 03:46 PM
  #40
TURBODAWG's Avatar
Yep...... Thats stage 1.....
Old Jan 27, 2006 | 05:43 PM
  #41
Stage two should be awesome baby!
Old Jan 27, 2006 | 06:35 PM
  #42
matt?
Old Jan 27, 2006 | 06:50 PM
  #43
Originally Posted by blowoffsilver
matt?
Hi Kasey.
Old Jan 27, 2006 | 06:53 PM
  #44
DynoFlash's Avatar
Brian
Bro - the plugs on the IX are totally different than those on the 8
When we were tuning the IX stroker (also with the HKS twin fire) we had problems with the stock IX plugs
The evo 8 plugs dont work in the IX
the stock IX plugs are gapped to 22
Old Jan 27, 2006 | 06:55 PM
  #45
DynoFlash's Avatar
War - your car is on alcohol which makes more demands on the spark - wehn you run staight race gas the car is leaner so it burns easier
