All You GT35r Guy's
Old Jan 30, 2006 | 03:52 PM
LIFER's Avatar
All You GT35r Guy's
Ok well I have recently built my motor w/the part's you can see in my sig.. I also purchased a 35r kit, and I have a buch of question's for you 35r guy's..
1st. Are you on a stock tranny and or t/c if so how long have you been?
2nd. What clutch are you running?
3rd. What Whp/TQ have you put down?
4th. What 1/4 mile times and trapspeed's have you seen?
5th. What injector's are you running?
6th. What cam's are you using?
7th. What kit are you running?
8th. What rpm do you hit full boost?
If you do not run or have experiance with the 35r please do not repond. This thread is meant to be a quick refrence for those of us with, or looking to purchase a 35r. Thank's in advance
Old Jan 30, 2006 | 04:16 PM
TrinaBabe's Avatar
I broke the stock first gear and rebuilt the tranny.
Stock Transfer Case
I broke that with an ACT street disc and pressure plate.
I now am running a Quartermaster twin-disc (ACT was being overpowered.. didnt last too long)
Never dynoed the POS
Ran a craptastic 11.5 @ 123.5 (Had quite a few problems with the car as well).
Maxxing out "780cc"s
272 Cams (Id go bigger definately)
I dont use "kits"
Lag is dependant on gear... there are a few threads discussing it. Assume to be around 5.5k in first and second... slightly lower in 3rd and a little lower than that in 4th. Spool is overrated anyways... the stock motor can spin to 8.5k every day of the week and do just fine... plenty of Rs to use the GT35r.
Judging by your sig you will be perfectly fine running around 40psi shifting at 9k or so. Injectors should be ok. Your fuel pump should be upgraded. Get some tires and run some low 10's.
Old Jan 30, 2006 | 04:40 PM
11secEVO7's Avatar
you can check my sig for all my upgrades..
as for boost i get full boost around 5000rpms to be honest.
I am still on the 2 litre and have been on the stock tranny and tcase for 4 years now!
and i launch the hell out of my car btw
Old Jan 30, 2006 | 05:13 PM
evolved69's Avatar
Tranny is shot
Act street disc
450wph on 20psi pump gas
haven't been to the track because i blew the motor(car is headed to ams for a intense build)
750
264/272 hks
atp....sucks....new ams stuff is on its way...
Old Jan 30, 2006 | 10:07 PM
LIFER's Avatar
keep em coming, thanks guy's
Old Jan 30, 2006 | 10:17 PM
G20's Avatar
G20
Yes! The car is 3 years and the GT35r is 14 months. Maybe sending to TRE or Shep in hope to fix high rpm/4th gear locked out problem. Everything works perfect on daily street driving.
ACT -> ACT -> Exedy twin (good so far)
410/325 on 91 and 530/410 on c16 all on dynojet.
Good at launch, suck at shift, 3/4 gear problem hence 12.2 / 122mph
Precision 780cc
264/272
RNR with equal-length manifold.
4700-4900 rpm
Old Jan 30, 2006 | 10:32 PM
SeanJhn9's Avatar
how many of you are doing this on an 05 or newer w/ the beefed up t-case/acd & tranny
Old Jan 31, 2006 | 07:40 AM
LIFER's Avatar
I know more than 4 people on here have 35r's, come on guy's share the info.. please..
Old Jan 31, 2006 | 07:48 AM
Rollaway's Avatar
Well one of my old setups on my 03 WW I made:
444.4 whp 393.3 tq on 93 pump and 22psi
Mods were:
Buschur Stage 4
AMS GT35R Turbo Kit
DynoFlashed
Stock Block
Denso 660cc
Ive added:
Magnus Intake Manifold
Accufab 75mm TB
1000cc
AEM EMS
made 450whp and 375tq on 93 pump and 21psi
yes not much power difference but it was more reliable.. kinda
Old Jan 31, 2006 | 07:54 AM
DCSilvrEvo's Avatar
ROLLAWAY! So You had a flashed 35R makin 444WHP?! No SAFC? im guessing custom flash?!
Old Jan 31, 2006 | 08:05 AM
Rollaway's Avatar
Yeah those were the good old days... Yes it was a custom flash... The safc I had was there but was never used after my tune
Oh yeah I forgot to mention my clutch.. it was on OS Giken Twin Disk with Push Type conversion...
HKS 272/272
Stock Everything else, such as STOCK UPPER IC PIPE for the 444.4whp
Ive hit 27psi in 4200rpms.. I dont remember when I hit 22psi though.. its been over a year since I had this kit
Old Jan 31, 2006 | 08:12 AM
DCSilvrEvo's Avatar
Ok GREAT because I cant afford a AEM right now. I will just get a custom flash for now and later on do some more mods. I got 750CC RC Injectors on standby thats good enough for A custom 35R with 272/264 GSC cams on stock gears?
Old Jan 31, 2006 | 08:16 AM
Rollaway's Avatar
I had stock gears also and only 660cc for the 444whp... You shouldnt have any problems.. on race gas and much higher boost the 750cc might be a problem depending on how far you want to go..
The gt35r shines at 27psi and above... once you get there you dont want to set your boost any lower
Old Jan 31, 2006 | 12:57 PM
sleet's Avatar
HKS 272/272
27PSI @ 4.2k, was that on the stock 2.0L?
Old Jan 31, 2006 | 01:37 PM
kcevo's Avatar
LIFER,
Curious as to why you switched from the Vpro to the AEM EMS, as I have done the opposite of what you did?
OH
1)Built tranny & T-case from TRE with longer final drive and LSD
2)Exedy triple carbon with heavy duty pressure plate
3)Haven't dynoed with the 35r and built motor, but stock block = 485whp/?tq on a mustange dyno at 27psi
4)Never ran it at the track with the 35r
5)Rochester 1000cc
6)HKS 280's, but looking for something more aggressive
7)AMS 35r
8)Latest logs were showing 14pounds(w/g pressure for now) at 3800-3900 in 3rd gear on the street
