clutch problem
Old Feb 2, 2006 | 03:20 PM
WEVO's Avatar
clutch problem
My stock clutch feels all mushy and soft now and when I'm in first gear the clutch doesn't seem to engage as well as it use to be, the engagement point seems to be very sloppy and blury. However, when I shift in any other gears, the rmp doesn't go up then down. Is my clutch going bad? Please help!
Old Feb 2, 2006 | 03:47 PM
evo8rcr's Avatar
bump for similar issues
Old Feb 2, 2006 | 03:50 PM
smokedmustang's Avatar
Have you checked your brake fluid? THe fluid is used for both. go check the line. Did you do the 1/2/3 Then 5th gear? skip 4th, and stomp on it for a while, and see if the tach jumps. How many miles, mods, driving style sure would help!!!!!!
Old Feb 2, 2006 | 08:10 PM
WEVO's Avatar
I have a bit more than 9000 miles on my car, and I also have a TBE, drop in filter and a gfb bov. How does brake fluid affect the clutch? Thanks
Old Feb 2, 2006 | 10:04 PM
EVOlution561's Avatar
i think i am having the sam problem, do you feel the car kind of shaking when you release the clutch in first?
Old Feb 2, 2006 | 10:29 PM
1Crazy8's Avatar
Same prob i have, i have launched the car, and am hard on it, i have almost every bolt on except turbo, im around 400HP What is a good clutch to get, i dont want the Exedy i want an ACT Kit!
Old Feb 2, 2006 | 11:18 PM
WEVO's Avatar
I don't think my car shakes when I release the clutch in first. But, the feel of the clutch is really sloppy. What can I do to improve that?
Old Feb 3, 2006 | 12:48 AM
EFIxMR's Avatar
may try changing the fluid and bleeding the system.
Old Feb 3, 2006 | 02:39 AM
They "share" the same fluid, out of the same resivoir. Good luck.
Old Feb 3, 2006 | 06:17 AM
IPS Mike's Avatar
Registered User
i would say start picking your clutches
i personally would recommend exedy twin disc
Old Feb 4, 2006 | 08:36 AM
just get a new clutch then
Old Feb 4, 2006 | 08:37 AM
I would get a high performance clutch
Old Feb 4, 2006 | 08:41 AM
Spooldyou's Avatar
get a clutch, not to many people have had to much luck with the stocker, but they do exist.
Old Feb 4, 2006 | 08:44 AM
Greg K's Avatar
1st - check the fluid level.
2nd - adjust the clutch pedal engagement rod under the dash
as the clutch wears, the level will drop, the thickness of the disk will go down, and your pickup point will get progressively higher. By adjusting the rod you can put the pickup point back where it belongs.
24k+ and the stock clutch is still going strong.
McSlides
Oct 17, 2014 09:44 PM
gkew
Jul 27, 2013 08:22 AM
MitsuJDM
23
Feb 23, 2013 02:07 AM
GsrJake
Dec 15, 2012 04:48 PM
KazzEvo8
11
Sep 12, 2006 08:53 AM
