View Poll Results: tme or br ported 10.5
tme
28.57%
ported 10.5
71.43%
Voters: 7. You may not vote on this poll
need some help guys..TME or 10.5
Old Feb 3, 2006 | 08:24 PM
sloty27's Avatar
hey guys a in week or so im plan doin a whole lot of mods ..now i have an 03 evo so i have a 9.8 hot side..now im thinkin..should i got with a br ported 10.5 or go wit a tme turbo..
how much whp should i expect wit each setup??..i have all the supportin mods to go wit it like 272s turboback intake i/c pipin etc etc etc..
also wut other mods would u guys should i do??
any1 usin the dc manifold??
Old Feb 3, 2006 | 08:33 PM
bolsen's Avatar
Hello
Old Feb 3, 2006 | 08:35 PM
JTB's Avatar
JTB
The TME comes with a 10.5.
The reason to get the TME is to improve spool whereas just the 10.5 will actually hurt spool slightly but improve top end.
Give us some background. What are your goals?
Old Feb 3, 2006 | 08:52 PM
sloty27's Avatar
well im lookin for 340-360whp wit a flash on pump
Old Feb 3, 2006 | 08:56 PM
use2vtec's Avatar
Just go with a ported 10.5 or even a regular 10.5 housing. The TME will not yield any extra power than the stocker with a 10.5 housing. It will just spool a few hundred RPMS sooner. Based on the cost of each I say go with the housing. Its almost 1/4 the price as the TME.
Old Feb 3, 2006 | 09:00 PM
sloty27's Avatar
so thats the only thing the tme does..spool faster?
Old Feb 4, 2006 | 08:13 AM
WillEatUrSTi's Avatar
When you buy the TME you get the 10.5 housing thus you'll have more top end but the TME upgrade will spool the turbo faster thus more power sooner. My vote is TME turbo unless you plan on different turbo down the road.
Old Feb 4, 2006 | 10:19 AM
Evotech8's Avatar
Both the TME or 10.5 housing will get you about the same HP. The TME will have slightly better spool. I recommend if your going to get either one you also get a O2 housing to maximize exhaust flow. I got the 10.5/O2 housing because it was cheaper than the TME and gets the same performance. I'm planning to upgrade to a Buscher 20G-9 turbo which is about the same price.
Old Feb 4, 2006 | 01:34 PM
Yes you may want to consider a 20G-9 I believe Buschur has already made some with the TME upgrade as well im not sure of the performance though.
Old Feb 4, 2006 | 05:03 PM
4-BNGR's Avatar
just buy my hotside I got the TME coming soon (wed/thr)...
Old Feb 4, 2006 | 05:21 PM
Gruppe-S's Avatar
Just FYI, the JDM EVO IX turbo has both a larger compressor and turbine side than the TME turbo.
Cheers,
Gary
Gruppe-S
