direction in next step of modding
Old Feb 6, 2006 | 12:25 AM
BigAeVo's Avatar
Sup guys just seeking a little advice on my next set of mods, i dont wanna go to crazy with the car right now but who knows it may change anyways. i currently have
HKS catback
Helix HFC
Helix DP
Dynoflash
HKS recirc VTA but will be recirc
Hallman boost controller set at 21
works drop in filter going in soon.
255 fuel pump
Im plan on getting GSC 272/264 cams
not sure what else i should go with i have about 600-800 left to spend
im thinking some plugs maybe licp.
also my car is tuned for a aem intake but i took that out, anyone see any major problems with that? thx for the help.
Old Feb 6, 2006 | 05:53 PM
ptevo03's Avatar
being tune for something then taking it out is not a good idea and as far as the cams go ahead a spend the extra buck for hks cams the gsc cams are cracking after alot of miles and for the extra money get full intercooler piping this helps alot. just my 2cents
Old Feb 6, 2006 | 06:11 PM
Ultimate CC's Avatar
Replacing the intake will surely mess up the tune, especially replacing with a very different intake. I would do gsc cams and arp headstuds next. A licp is a good idea but not needed. As far as cracking cams goes, do your research and you will see what that was all about, the new v2 have no problems watsoever.
Old Feb 6, 2006 | 08:01 PM
BigAeVo's Avatar
alright im also thinking about 02 housing and 10.5 hotside, im sure i should get some new plugs that are colder also. i took out my aem and put back the stock.
Old Feb 6, 2006 | 08:03 PM
4-BNGR's Avatar
HKS catback
Helix HFC
Helix DP
Dynoflash
255 fuel pump
264/272 not 272/264. Get a SAFCII instead of Dynoflash. DIY
Old Feb 6, 2006 | 08:20 PM
Warrtalon's Avatar
Not sure what 4-BNGR's problem is, but he obviously has a chip on his shoulder. There's absolutely no reason to take your Dynoflashed car and get an SAFC instead of it. That's ***-backwards and completely asinine. Also, 272i/264e is fine. People have been doing that a lot recently and that is the exact combo I will be running in a few weeks.
With the cams, get arp head studs, the Buschur LICP, and a custom reflash. You should have enough cash to toss in a 10.5 and o2, also. This will set you up nicely...
Old Feb 6, 2006 | 08:36 PM
BigAeVo's Avatar
what plugs you guys recommend with my setup
Old Feb 6, 2006 | 08:52 PM
bpr7es
Old Feb 6, 2006 | 09:11 PM
Warrtalon's Avatar
With the mods you have now, use BPR7ES gapped to .026. With the addition of the mods I listed, get BR8ES gapped to .026, but keep a set of BPR7ES spare at all times just in case. I keep extra sets spare, because they are very cheap, and you never know when you might need them.
RSGuy
Mar 19, 2011 11:13 AM
hurstnova350
14
Dec 19, 2008 12:38 PM
dbotkin5
Jan 27, 2008 04:40 PM
Gruppe-S
29
Nov 30, 2006 12:18 PM
