400AWHP Suggestions
Originally Posted by evo0486t
-warrtalon: just curious.. are you saying that it is completely impossible to hit the 400s AWHP with the stockie and 93 pump.... no race gas, no meth or nitrous... just plain 93 pump...?
Originally Posted by Soon2BEVO
Yes, thats he is saying and I am saying.
!!! we'll just have to wait and see..!! personally i don't think its impossible.. but u never know..!!
Using 100oct is about equivalent to having alky, so it's advisable not to omit that tidbit of information.
I've been to alot of dyno's here in Colorado and I've never seen anyone on the stock turbo/91 oct. hit anywhere close to 390awhp/tq. MAC has recommended bigger injectors but I didn't go that route. I think they suggested the bigger injectors to manipulate timming if one is on SAFCII. Nick/MAC showed me another guys dyno (claiming to be the highest numbered EVO there with less mod then me) and it was somewhere around 380awhp/tq. I can tell you, I personally didn't believe it because they were claiming 91 oct. I believe 100 oct was used and high boost was in the factor but I'm sure MAC couldn't verify it, they just took whatever the guy said. Don't believe everything you see or hear out there guys, it's not all true, theres compensation somewhere for someone to be running with such high numbers on the roller.
Originally Posted by 4-BNGR
did you dyno with 17's or your 18's? I think the 17's would make more power - guessing...
Originally Posted by dsmfan95
I'll just 100oct then if it's about the same. Save myself from getting the alky kit.
Yes, I say that 400awhp is not FEASIBLY possible on the stock 03-05 turbo with straight 93, but I'm sure someone could try everything possible and spend a lot of money to achieve it. It wouldn't be cost-effective or safe, but it could probably be done if someone really wanted to do it for one or two glory runs on the dyno...
For 05s with the 10.5 (for 03s, add 10.5)
300whp - Warrtalon Stage 2 (tbe/mbc/bov/fp/flash)
330-340whp - Cams/LICP
380-390whp - Alky/manifold/o2
Beyond this, you need a turbo upgrade, and that's outside my experience.
Is this on 93 or 91 oct? I seem to see that tuning at lower HP levels (about 300whp) on 91 gives up about 10-15hp vs. 93 oct. Does this correlation continue at higher HP levels? My first guess would be if you do not maintain VE because of higher heat levels (due to running close or out of efficiency range, build up of BP on hotside, not enough cooling at the intercooler, fussing with timing, etc) you're going to lose more and more on 91. Can you gain more headroom on 91 by starting to use fuel for cooling? (seems that's what those with monster injectors try on safc, but it becomes a fuel pig), or going to a larger intercooler?
Any input yet on the IX?
warrtalon, why do u have to be dissing people left and right, im just asking for suggestions here, not to be insulted...
Originally Posted by DrMerl
Thank you for that start.
I have a good stage 1 for the IX, but I'll wait to list that when the actual package is released.
