Boost Issue!
Old Feb 10, 2006 | 12:55 PM
brandonbigdog's Avatar
Boost Issue!
i have a turbo xs manual boost controller and i cant boost above 1.3 bar! All i get is fuel cut! I run 92 octane chevron only gas! Any one have this problem?
Mods are:
intake
3" catback with gutted cat
MBC
Safc-2
Old Feb 10, 2006 | 12:58 PM
joshd's Avatar
A better boost controller, an accurate boost guage, and a flash to remove the fuel cut and provide a better tune than the S-AFC might be good things for your car's future ...
Old Feb 10, 2006 | 01:26 PM
how acurate is the stock boost gauge? and can a have a flash and the safc-2 running together?
Old Feb 10, 2006 | 01:41 PM
Warrtalon's Avatar
It's accurate enough, but if you ever want to run more than 21.75psi, get a new one. You can run the flash and SAFC together, but I'm sure you knew that, since you already searched before making this thread, right? With a tuned SAFC, there should be enough fuel removed to delay fuel cut unless running very high boost (23-24psi?). YOu shouldn't hit fuel cut at pump gas boost levels with a tuned SAFC, but with a Dynoflash, fuel cut will be gone for good.
You also have what is perhaps the worst MBC for the Evo. Why do people keep buying that piece of crap? I have no idea what site or vendor keeps pushing TXS parts, but it has to be someone, because everyday I see a new poster on this site with some TXS part that isn't really recommended.
Old Feb 10, 2006 | 03:05 PM
thanks for the advice on the boost controller! I didnt buy it a friend let me put it on! What is a recommended but not super expensive boost controller then? And also i am getting my ecu flashed in april by al(just a basic flash) so hopefully that will help! I also failed to mention that i have a larger FMIC! Thanks for the help guys!
Old Feb 10, 2006 | 07:56 PM
Warrtalon's Avatar
Larger FMIC already? Unbelievable again...
View my sig for the exact brands and mods I suggest.
Old Feb 11, 2006 | 01:17 PM
yeah i upgraded the FMIC because the stock one got thrashed from gravel on the road! But the fuel cut started before the front mount! I think i am going to bump up my flash date to the 11th of march!
Old Feb 11, 2006 | 01:47 PM
Warrtalon's Avatar
Good, Al will be in Portland that weekend.
TCSTigersClaw
Mar 12, 2014 01:43 PM
SoolingEvoVIII
42
Jul 3, 2011 01:43 PM
19fred82
Jun 14, 2011 06:39 PM
shadow1
Sep 12, 2010 09:27 AM
blue beast
Mar 29, 2004 02:52 PM
