Buschur Racing teams up with Warrtalon....
Originally Posted by MRinChrist
I meant the VIII MR.
Thanks for the info, depressing...
...It is all about the MIVEC, huh?
...It is all about the MIVEC, huh?Yes, it's depressing.
No, the MIVEC only works up to 6k, so it provides a lot of power in the low-end and mid-range while also assisting spool time, but the higher power seems to come from the larger compressor housing and coolant passages in the head that allow for more timing without knock.
Godspeed!
The turbo is not actually "larger". The compressor housing is only larger, the wheels inside of the turbo are still the same size. Just a re-designed cover.
David Buschur
www.buschurracing.com
David Buschur
David Buschur
David Buschur
Could someone explain why a dynoflash still needs an upgraded fuel pump and MBC; while no other tuner recommends that?
I've heard others (maybe Shiv even) claim the stock fuel pump is good to over 400hp.
Either it's overkill to be safe, or a dynoflash is pumping through a lot more fuel to cover knock?
Since when do no other tuners recommend an upgraded fuel pump anyway? And since when do no other tuners recommend an MBC? You've been token the pipe, eh?
Buschur/Warrtalon EVO VIII Stage 1 - $1575
- Bushur Racing Turboback Exhaust with your choice of Hi-Flow Cat or Test Pipe and choice muffler (quite or loud)
- Forge UNOS MBC
- Autometer -30 - +30 Boost Gauge + single pillar pod
- Forge RS DV (adjustable one that I use)
- Walbro 255lph fuel pump
- Buschur Stg1 Flash perfected by Al for this specific combo
so your telling me with this setup, it will make my little 03 evo 8 have 300hp because its super stock right now.
- Forge UNOS MBC
Shiv claims the stock fuel pump is good to over 400whp??? Are you sure about that? I haven't seen any tuner NOT recommend a fuel pump at such crazy power levels for the stock turbo. You realize that to put down 400whp on an VIII, you have to be pushing over 25psi. This is where it becomes dangerous to still be using the stock fuel pump. Also, the stockers have been known to fail at times. So, we recommend getting one when running 21+ psi and over 300whp just to be safe. No, it's not to cover knock...come on, man. It's an $85 item that can save you $3000-4000. It's also something you want to do along with the flash, because if you do it after the flash, then you have to get retuned. Notice that IXs don't need it, since there's appears to be upgraded.
And with a 'base' flash, nobody gets tuned over 21 psi, so why the need for a fuel pump? And why the need for an MBC - still tricking out the ecu? Ecutek flashes and Works don't need an MBC.
Re-Read my post - I said 400hp - not whp.
Yes, people can and do run more than 21psi on base flashes. I ran my 12.26 on a base flash and 22psi. There are people who run 23psi and some who claim 24psi on pump gas, although I don't agree with doing that.
Why the need for an MBC? Hey, look, if you just want basic low boost controlled by your flash, that's fine. Dynoflash can do it, too, but that is very rare. 90% (if not more) of us who mod get an MBC so that we have full control. You buy no means HAVE to have one with a Dynoflash, but that is what I recommend, so that's why it's in my package.
- Forge UNOS MBC
- Forge UNOS MBC
Yes, unless you choose the HFC option, which will probably rob about 10whp.
BR stage1. Yeha im going ot be running the HFC. Whats the Tq number? Also what size spring is in the Forge UNOS MBC
Oh ok nice well Im trying to decide if im going to go with this package or the
The torque numbers will be equal to or greater than the WHP with a Dynoflash as long as you run the proper boost (20+ psi). So, if you do the HFC, you might see 290whp/290-295wtq.
The UNOS should come with both springs, but it usually has the soft spring in it by default. Some places like Dynoflash go ahead and put the stiff spring in there, since we really have no use for the soft spring, but when you get it, you just have to test it and make sure. I always recommend leaving it how you get it, then install it, set it to minimum, and go test the boost. If you start out at ~11psi, then it's the soft spring. Instead of messing with the soft spring, I recommend that you immediately take it apart, switch in the stiff spring, ENSURE THAT IT IS FULLY SEATED ON THE NIPPLE, grease the ball lightly with fully synthetic grease, then reassemble. Again, test the boost at the minimum setting. AT this point, it should show ~17psi. You can then start making slight adjustments until you get to 21-22psi peak in 3rd gear on 93oct. The UNOS has clicks that allow you to remember exactly how far you've gone, which makes it extremely easy to dial in.
