Best shift point with upgraded ex/int
Old Feb 15, 2006 | 08:38 PM
Kevine326's Avatar
Searched but didnt find it...
Anybody have a good idea what the best shift range is with the stock turbo and a upgraded intake/exhaust? (3" full exhaust)
Asking cause at some rpm the backflow has got to be more detrimental than shifting. On the stock setup it seems like right around 6.5k im losing power but still gaining speed. Looking for that optimum rpm where you are still gaining both.
I know it sounds wierd but feel its a valid enough question to ask.
thanks
Old Feb 15, 2006 | 08:56 PM
Links0000's Avatar
HAHA I thought the title meant best shift point with upgraded interior/exterior! WOW I need some sleep
Old Feb 15, 2006 | 08:57 PM
dankvw420's Avatar
I believe that you want to know when your car is making the most power at a certain rpm. I would get dynoed and see at what rpm you make the most power and try to shift there or just at redline. Hopefully this helps you out a little.
Old Feb 15, 2006 | 08:59 PM
Warrtalon's Avatar
It's different for every car. It depends on the power you're making, where you're making it, how quickly you shift, how much boost you're running, your altitude, the year of your Evo, the gearing, etc etc etc. You didn't find an answer to this for several reasons: there's no direct answer for this, and you didn't look in the drag racing forum where this is discussed most often.
Old Feb 15, 2006 | 09:58 PM
jmartinez1170's Avatar
are you kidding me with this ? comeon.
ITS CALLED DRIVE YOUR CAR AND FIND OUT
Old Feb 16, 2006 | 05:27 AM
Kevine326's Avatar
Constructive thx! Dont have the parts installed yet and considering alot of the first step upgraded evos are just full exhaust and intake without really touching the fuel system it would be similiar for most of the cars.
Ill look in the other other forums as the previous person suggested.
Old Feb 16, 2006 | 09:31 AM
Ludikraut's Avatar
If you have a dyno chart, you can calculate the theoretical shift point and then fine-tune it for whatever type of racing you do. But it seems that, generally speaking, the more power you make on your Evo, the higher the shift point creeps...
l8r)
Old Feb 16, 2006 | 11:22 AM
sonicnofadz's Avatar
rofl
chaotichoax
Apr 12, 2020 11:55 PM
Hiboost
26
Dec 30, 2009 04:28 PM
evo_soul
Lancer Engine Tech
Jan 14, 2008 11:59 AM
TKVK1
Driving Techniques
79
Jun 26, 2007 11:36 PM
blackvii
23
Nov 18, 2004 03:47 AM
