JDM EVO IX Tested & Tuned
Originally Posted by Kee1pride
is a buschur 20g-9 any different than the stock evo9 turbo? they both fit exactly the same with the 20g-9 install kit? if so i will have to order that. thanks a bunch
I don't know if someone mentioned this, but JDM IX Turbo is different than USDM IX turbo.
It's like 6.5 TME, but with a different twin scroll design.
USDM IX turbo doesn't have the titanium magnesium turbine and shaft.
How much is the JDM IX Turbo go for?
Originally Posted by Az3ar
Why do I feel that you are hating on the Mivec? Are you smarter than Mitsu? There is no 10% here and 90% there. The smoothness of the IX and the power it delivers is a mix in everything starting from the turbo through the head ending with the muffler.
People are picking the IX to keep their warranty. Can you keep your warranty after slapping a nine turbo in?
Even an 8 with IX turbo wont make as much power.
Furthermore, it’s only the beginning of tuning the IX as tuners have just released their flashes. Vishnu does not have one of his own yet and Works will have theirs out in 6 weeks. Al has one I believe. Give them 1 year and the same IX that makes 370 will make 390WHP.
Remember when EVOS cam out? They used to make 300 WHP with cams but suddenly after many tunes tuners started to extract more power, ALOT MORE POWER.
Don't hate on the IX its just another EVO.
... but neither does anyone else, this also includes the tuners. That is what I'm trying to point out, most of the tuners came out and said most of the gains the 9 has over the 8 is because of MIVEC. I just didn't agree with them because on BMI
engineers came out and said the 9 turbo was responsible for most of the low to mid range gain because of an upgraded diffuser design and MIVEC was there to help the engine become more fuel efficient and emissions compliant.The STi has active valve control system (similar to MIVEC, VTEC, etc) that none of the tuners wowed about over the EVO. Hell Mazdaspeed engineers took out vaiable valve timing from the regular mx-5 miata when they designed and built the mazdaspeed miata because they claimed that vvt didn't do much for power gain on the mazdaspeed miata. They said it made it more complex and less robust. But as soon as the EVO got it most tuners were quick to say MIVEC was responsible for most of the power output. I didn't know whether they were right but it contradicts with what
had said
I thought the true test would be an EVO8 and EVO9 both with the EVO9 turbo and identical mods (eg: only TBE). Then tune and dyno them and compare the graphs. If the 9 still has a significant advantage (more than 10WHP) then it would be because of the MIVEC, revise head, revised pistons and revised ECU. But if it is less then 10WHP then most of the gain would be because of the turbo and the other stuff wouldn't mean much. I've been one who was vocal saying it was mostly the EVO 9 turbo and not MIVEC that was responsible for the gains.
Here is the thing, tuning is not rocket science and if a tuner does a good job to begin with there will be no magical gain over time. All factors, like AFR, boost, ignition advance, boost under load, etc will be safely pushed to their limit. Look at the Shiv's and Work's tunes, they haven't changed since they originally tuned the EVO. I'm not knocking Al in anyway, he has come a long way from when he first started tuning EVOs and I now believe he is on the same level as Shiv. Infact, Al was the only one who agreed with me that most of the gain was because of the turbo. There hasn't been any magical gain with them. I respect the tuners and I know they know much more than I do, but I don't think they know more than
....If you are happy with your EVO9, I am happy for you ... especially after the turbo upgrade you did on the EVO8 and the things that happened between you and the Vishnu group. No hate man just looking for some answers ...
Originally Posted by razorlab
I believe they mean going from a 10.5 hotside 05 turbo to a IX turbo.
The gain from the 9.8 to IX turbo is of course, more. Like going from a 9.8 to a 10.5 hotside + whatever advantage the IX turbo gives you.
Originally Posted by Soon2BEVO
Um ok, but they tuned a 2003 (with a 9.8) and theyre saying they think the EVO IX turbo is worth 15-20HP over the EVO VIII turbo. So your assuming theyre talking about the EVO8-10.5 turbo? I just want to know whyd theyd make a claim about HP gains over a certain turbo they didnt test (specificially the 10.5 8 turbo).
car comes in with stock 8 turbo with 9.8 and baselines at 265WHP
car has stock 9 turbo put on and leaves with 300WHP
total gain = 300-265 = 35WHP
if the car had a stock 8 turbo with 10.5 it would have baselined 280WHP because a 10.5 usually gives you 15WHP more. Which means the stock 9 turbo is good for 15-20WHP more than the stock 8 turbo with 10.5 ...
What's so hard to understand?
Originally Posted by DaWorstPlaya
I think someone needs a lesson in math:
Thats funny. Maybe you need a reading lesson, because my math skills are great. In the first post Gary said it got the EVOIX turbo and an ECUTEK tune. So that 35whp is from the turbo AND the tune. If they just strapped on the turbo and tuned it alone, OK, but it said NOTHING about a previous tune... if it did have one, it should have been written in there dont you tihnk?
Sounds right to me. Maybe someone wants to give me a IX turbo for my car and then we can really tell what the gains are from a 10.5 05 turbo to a IX turbo.
Well what I said was more from what I am seeing with that 03 with IX turbo overlayed upon my cars curves. If you put a testpipe and did the same cam gear changes I did on my car, I can see it making about 15-20whp more than my 10.5 hotside 05.
The customer's vehicle had the following modifications:
*264 / 272 cams, cam gears
*02 housing, downpipe, exhaust
*CATTED
*720cc injectors, walbro pump
cams, 720 injectors and fuel pump alone would need a flash
common sense ...
Ok, that makes sense the way you put it, but the original wording in the first post just didnt impress me. 35whp from a turbo upgrade AND a flash.. ya know.
He did have a tune before to make the 265awhp, which btw, isn't shabby for a catted 9.8 hotside car on that dyno.
Ummm, okay you don't think a car would have to have a prior tune with the following mods:
*CATTED
common sense ...
*CATTED
common sense ...
I think it would be plenty possible to have a tune beforehand but what if he just installed those parts
Is that sooo unlikely? I mean I see what you mean but he came in for a tune, and it was NOT mentioned he had a tune prior. I just wanted clarification for the numbers posted. I like things to be clear and concise and the first post did not do that. Thanks.
yes agreed the original post is a little confusing.
Umm okay, why dont you stop being an ignorant shmuck with that condescending attitude, its getting old.
Obviously you got offended by the fun I poked at you with my last comment. No need to get you panties in a twist ... I only gave you the
after you made the same
comment ... did I call you any names?
