fic 850 lag timing
Old Feb 21, 2006 | 01:03 AM
spyke's Avatar
fic 850 lag timing
Hi ,
Has somebody got the injector lag timing for the fuel injector clinic 850cc injectors?
thanks
sven
Old Feb 21, 2006 | 05:00 AM
GTVEVO's Avatar
Originally Posted by spyke
Hi ,
thanks
sven
Are you refering to the injector battery offset, or the actual time it takes the fuel to make it down the intake track?
Old Feb 22, 2006 | 07:41 AM
spyke's Avatar
the differant voltages,as you need to alter them in the ecu (power fc)
thanks
sven
Old Feb 22, 2006 | 08:21 AM
GTVEVO's Avatar
thanks
sven
Here are some voltage against time below for the FIC 850cc, I hope this helps.
Volts uSec
6v 2550 uSec
7v 2370 uSec
8v 1690 uSec
9v 1300 uSec
10v 1020 uSec
11v 870 uSec
12v 740 uSec
13v 620 uSec
14v 510 uSec
15v 430 uSec
16v 370 uSec
Old Feb 23, 2006 | 09:55 AM
spyke's Avatar
gtvevo,
thanks just what I needed
sven
ps where did you have that info from?
Old Feb 23, 2006 | 11:57 AM
GTVEVO's Avatar
gtvevo,
sven
I run the same injectors on my AEM, But AEM does latency to voltage testing on several different brands and sizes for their EMS.
Glad I could help
Old Feb 24, 2006 | 10:51 AM
spyke's Avatar
Yep thanks mate,
What turbo are you running?
sven
Old Feb 24, 2006 | 12:04 PM
GTVEVO's Avatar
Yep thanks mate,
sven
GT30R (-15 CHRA) TO4S Inlet / .63 Exhaust side.
Old Feb 28, 2006 | 01:10 AM
spyke's Avatar
I have the same but with a 82 housing.
Do you think the injectors are big enough for a gt35(82 housing) ?
sven
Old Feb 28, 2006 | 05:53 AM
GTVEVO's Avatar
sven
They are not big enought for a GT35R with either housing, you will need 1000cc injectors if you are going to push the GT35R to its limit. The 30R will push the 850cc to their limit on a 2.0. If you are turning some really high rpms with either set you still may need to go bigger with the 30R and the 35R.
Old Feb 28, 2006 | 06:54 AM
Ted B's Avatar
** 850cc min **
- S.G. gasoline = 0.69, which = 0.69g/cc
- (0.69g)*(850cc/min) = 586.5g/min
- (586.5g/min) / (454g/lb) = 1.29 lb/min
- (1.29lb/min) * (60min/hr) = 77.5lb/hr
- (77.5lb/hr) / BSFC of 0.55lb/bhp/hr = 141bhp
- (141bhp) * (4 injectors) = 564bhp
Therefore, a 850cc/min injector is good for a theoretical 560+bhp on a 4-cyl engine. What that equates to in 'whp' depends on the dyno. With a Dynojet, whp is probably close to bhp.
Notes:
- A ball-type injector (e.g. FIC, Lucas) will run more efficiently at higher duty cycles than a disc or pintle type (Denso, Bosch, etc.).
- Use of methanol reduces the injector load.
Old Mar 1, 2006 | 10:45 AM
spyke's Avatar
ted B
but they would be at 100% duty...
GTVEVO
Do you have the voltages for the fic 950?
sven
Old Mar 1, 2006 | 11:14 AM
GTVEVO's Avatar
ted B
GTVEVO
sven
Sure thing, I have posted the FIC 950cc 90lb 2ohm chart below.
Volts uSec
6v 2550 uSec
7v 2550 uSec
8v 2080 uSec
9v 1620 uSec
10v 1300 uSec
11v 1050 uSec
12v 880 uSec
13v 750 uSec
14v 650 uSec
15v 570 uSec
16v 510 uSec
Old Mar 1, 2006 | 11:47 AM
spyke's Avatar
Thanks again,and I presume these are good for the 35R?
sven
Old Mar 1, 2006 | 12:01 PM
Ted B's Avatar
ted B
No, they'd be at 80-90% duty.
Why?
Because most people aren't aware that injectors are typically rated at 80-90% duty.
