aftermarket oil coolers
so as some of you know i spun a bearing in my evo due to oil pump failure. im not going to risk using the stock oil cooler/lines because of possible metal shavings so i was wondering what are some options for an aftermarket piece. i searched and this topic really hasnt been discussed. the oem one is 388 and i know that i can get an aftermarket one for cheaper that will cool better. thanks for any help.
Originally Posted by nothere
If you want something plug and play, it's going to be hard if not impossible to find something as cheap as you're looking for.
Setrab makes one of the best cores out there for oil cooling. I have had personal friends use them and seen them on many race cars. If you're looking for just a core.. you will still need to factor in the fittings and the lines. Building a proper oil cooler setup is not cheap.
Ed @ Evasive
Ed @ Evasive
Pale Horse
Jul 26, 2013 09:47 PM
AlwaysinBoost
25
Jul 23, 2008 01:13 PM
