Aftermarket BOV's
Old Feb 26, 2006 | 03:54 PM
PKEVO8's Avatar
Question Aftermarket BOV's
This summer i am planning on buying some new aftermarket parts. Once I am done with those mods, I will be running around 375 whp. I was also thinkin about buying a new bov, but i'm not sure which one to buy. Should i stick with the stock bov, or go aftermarket? if aftermarket, then which one?
Old Feb 26, 2006 | 04:03 PM
Warrtalon's Avatar
First, let me make sure you'll really be around 375whp. To do that, I'm assuming you're getting:
- TBE
- MBC
- Cams
- LICP
- Alky
- Tune
If so, then you'll be running 26+psi, so you'll need a strong BOV. The stocker only holds 13psi before leaking. I suggest the Forge RS DV
AtO-MiX's Avatar
you still have that plasitc p.o.s. wow. I say go with the Forge RS or Forge recirc dv (older version) that or APS dual vent.
Old Feb 26, 2006 | 04:04 PM
GTKage's Avatar
go with the JDM MR bypass valve ( same as evo 9) or forge RS bypass
Old Feb 26, 2006 | 04:11 PM
PKEVO8's Avatar
yea trhats pretty much what im gonna be getting
Old Feb 26, 2006 | 04:59 PM
demon tech's Avatar
I like the HKS bov alot, I always had trouble adjusting other BOV's correctly such that they werent venting under boost - I never had that problem with the HKS, perhaps because it is a pull mechanism.
Old Feb 26, 2006 | 05:29 PM
bacalhau16's Avatar
The stocker isnt gonna cut it. I had a greddy type-s and i liked it a lot!
Funny how u knew that u were gonna have 375 whp but u still werent sure about your bov!
Old Feb 26, 2006 | 05:58 PM
Warrtalon's Avatar
JDM MR DV is great, but not above 24-25psi, so keep that in mind.
Old Feb 26, 2006 | 06:14 PM
TURBODAWG's Avatar
Forge RS hands down.... Best one for the money. Holds the boost period. Easily adjusted if you require at the track. If you need one, send me a PM.
Brian
Old Feb 26, 2006 | 06:16 PM
EvoDan2004's Avatar
i have aps dual vent bov. holds boost great but im only at 20/21 psi.
Old Feb 26, 2006 | 06:25 PM
Evo05lution's Avatar
if i remember correctly i heard that the APS holds up to about 26psi. If you are all about the bells and whistles then get the APS Bov, if not then get the Forge RS D/V, its the best Bov for the money hands down...
Old Feb 26, 2006 | 07:38 PM
Space Monkey's Avatar
I think your better off without an aftermarket bov, unless you just want the novelty sound. Other than that it really isn't good for much, and you can run into vacuum leak issues.
Old Feb 26, 2006 | 07:52 PM
era-teknic.com's Avatar
Are you serious?? The stock is a plastic good for nothing POS. I think what you want to say is get a aftermarket BOV that recirculates insted of vent to atmosphere so you don't have to worry about MAF issues.. You'll need it to run 375hp because to run 375hp you'll need to run 26psi or more.
Old Feb 26, 2006 | 08:40 PM
Warrtalon's Avatar
This is either a joke, or you're differentiating between DVs and BOVs without telling him the obvious, which is that he DOES need something to replace his POS stock, plastic BOV, such as the Forge RS DV that several of us have mentioned...
Old Feb 27, 2006 | 12:26 PM
GgreyEVOIX's Avatar
Can't it be modified to hold more boost? I remember with my sti the stock bpv would leak at 19-20psi so I had it modified and it would hold 25psi all day. When I run enough boost on my IX I'll mod the stock valve as well.
